  3. Determine the corner name using a "measurement" functio...
  • Subscribers 150
  • Views 1722
Determine the corner name using a "measurement" function
Ivars
Ivars over 11 years ago
I have a skill script that extracts a number of measurements from an ADEXL results database (post-simulation) and generates a formatted table. When applying this script to a corner simulation, I would like to determine the name of the corner associated with each child of the family so that I can use the corner name as the column header.
I apply each measurement function to the family of results, which returns a srrWave object. What I would like to do is apply a function such as cornerName() which would return a srrWave containing the corner names.
I can determine the corner names from the ADEXL results database, but what I need is a function that behaves just like a normal signal measurement function so that the ordering of the corner names matches that of the other measurements.
Is such a function possible?
Ivars
  • sgreenwo
    sgreenwo over 11 years ago
    Hi Ivars,
    There are probably many ways to do this, but it may depend on how you generate corners in ADEXL. If you have only a 1-dimensional sweep, you could use famGetSweepValues, documented in the skartistref, to retrieve a list of corner names. Since you said you need it as a waveform object, you can build up a waveform object from this list using drCreateVec, drSetElem, drPutWaveform*Vec, etc. If you have multi-dimensional sweep (which will happen when you generate ADEXL corners using the cross-product), I don't know a clean way to do it, but yesterday I posted a related question that may be of interest to you in case someone replies with a solution.
    Best,
    Stephen
