  3. passing boolean arguments to p-cell
  • Views 16360
mtwadeCU
mtwadeCU over 11 years ago
I'm trying to pass boolean arguments to a p-cell I've created, but the value in the p-cell always assumes the default value.
In my p-cell definition, I have:
pcDefinePCell(
list( ddGetObj(....) "layoutName" "layout")
( BooleanInput       nil )
let( () .... )) ;end pcDefinePCell
Then, I go to call the p-cell elsewhere, and pass in the BooleanInput to be true:
dbCreateParamInst( ...
list(
list("BooleanInput"     "boolean"     t)
) ; end dbCreateParamInst
However, the BooleanInput is always set to the default value defined in the p-cell definition -- in this case nil. Are boolean arguments allowed?
Mark
  • skillUser
    skillUser over 11 years ago
    Hi Mark,
    The following snippet is from the documentation, I think it may help you:
    Consider specifying the data type of a boolean argument as shown in the following example:
    (is_orthogonal_boolean_arg "boolean" nil)
    This is in the formal argument list of the PCell, i.e. in the pcDefinePCell statement.
    Hopefully this helps you!
    Lawrence.
  • mtwadeCU
    Thanks for the quick reply! Indeed, that fixed it!
