  3. tracking down markers from cell verifier for all cells in...
  • Subscribers 148
  • Views 14696
tracking down markers from cell verifier for all cells in a design
knuhcrek
knuhcrek over 11 years ago
Greetings all,
I'm an old hand at SKILL but all my experience has all been on the PCB side (Concept/Allegro) - this IC stuff has got me a bit bewildered.
Manually running Cell verifier against a particular cell ( or more precisely the layout view of a cell)  reports some shorts and some violations of weak connections and flags these with markers in the display.
Question: assuming I can build up a list of library objects and within those lists of cells and within those lists of views, how should I go about building up a list of markers? The overall goal here is to collect a list of all markers in a design . Do markers have their own objType? How are they tied to what they mark? In the Allegro world designs have DRCs and a DRC is its own instance of objType 'drc' and has a property that ties it to the dbids of the offending objects.
Any suggestions/hints/pointers/constructive criticisms and especially examples are all welcome.
TIA,
Chris Walters
(back from the netherregions)
  • skillUser
    skillUser over 11 years ago
    Hi Chris,
    If you are using IC61x or ICADV12x then you can use the Annotation Browser to help you view, visit and clear the markers, and in the database markers are their own type of object which are attached or reference the objects they mark.  If you get the cellview id (e.g. cv = geGetEditCellView()) then you should be able to see them in SKILL using something like cv~>markers. Unless you really need to write your own code, I would look first at what the Annotation Browser provides for viewing markers; they can be grouped into types on separate tabs, e.g. DRC markers on one, Constraint issues in another and so on.  There are controls for visibility for particular markers which can be controlled individually or by sub group (e.g. say you have 10 errors of type "abc" you can visit them individually, or turn on/off the entire set). You can modify the color of markers in the same way.
    Hopefully this is enough to help you get started?
    Lawrence.
