  3. Skill function for back-annotation
  • Replies 10
  • Subscribers 150
  • Views 19691
archive over 20 years ago
Any skill function for back-annotation ? Thanks, Michele
Originally posted in cdnusers.org by micheleq
    Back-annotation of what? Your question is rather imprecise...
    Originally posted in cdnusers.org by adbeckett
    I need to simply back-annotate W, L, and NF (number of fingers). Eventually, R, C for passives. I hope this helps. Michele
    It's still pretty vague. If these are CDF parameters, and you have the ILLabels
    cdsParam(1), cdsParam(2) etc on the symbol, you can use Edit->Component Display (I think that's the menu) in the schematic editor to control which CDF parameters get displayed in each cdsParam slot...
    archive over 19 years ago
    Back Annotation of .op current for symbol pin
    Can anyone help me understand how to display via cdsParam(1) back annotation of .op current in ADE/Hspice enviroment for a symbol(schematic) embedded in a simulation schematic.
    Paul
    Originally posted in cdnusers.org by dsnGuy49
    Hi Andrew, when i back annotate the region of operation of operation, cadence shows numbers, which refer to a particular region of operation. Is there a method to show the region (eg:sat, linear, off) instead of numbers.
    Amarnath
    Originally posted in cdnusers.org by amarnath
    You could always use your own label display function on a symbol to do the translation.
    However, you may be better off using the circuit conditions tool (Results->Circuit Conditions in ADE) to highlight devices in different
    regions in different colours...
    Nice idea, could be usefull, however in my case, the bsim3v3 model af the transistor sim ADE -> Result -> Circuit Conditions...
    The "region" caracteristic is not available (see attached print screen). How come ?
    Did I do something wrong ?
    Any idea ?
    Regards
    Originally posted in cdnusers.org by ebecheto
    I don't know why this should be. Probably you should contact customer support over this (I'm a bit busy to investigate right now).
    Hi Andrew,how do we get simulation data generated by simulators like hspice or eldo annotated into the cadence schematic....is there a way?
    amarnath
    Exactly the same way as you do it with spectre. If you're using Mentor's eldoD interface, or the Cadence hspiceD interface, then backannotation should work. The mechanism is the same - if the data is in the psf files, then it can be backannotated.
