  3. How to use 'hiAddFields()' for dynamically add fields inside...
  • Views 1489
How to use 'hiAddFields()' for dynamically add fields inside a TabField
Manikk0501
Manikk0501 over 11 years ago
            I want to dynamically trigger the addition of new fields in a MultiTab GUI through hiAddFields() SKILL command. How should i give the Form name arguement in this case since i want one of the Tab to get updated?
Thanks and Regards,
Manikandan Kuzandhaivelu
    If you have created a tab field with name ?name 'TabField (say), and you have the form data structure in a variable called (say) MyForm, then you would pass MyForm->TabField->page1 or ->page2  (you can use the name of the tab too - so if you created the tab with names Setup and Misc, then you can use ->page_Setup or ->page_Misc).
    This page is effectively a sub-form, and you can then add and delete  fields from it just as you would with a normal form.
