  3. How to use hiHighlightField() to highlight a particular...
  • Replies 7
  • Views 18472
How to use hiHighlightField() to highlight a particular field if the input is incorrect
Manikk0501
Manikk0501 over 11 years ago
Hi all,
                 I want to hightlight a particular field in a GUI with multiple tabs if the user input is incorrect(Let say it is a file input and the file name which user mentioned is not existing).
                 I added a ?modifyCallback function which has hiHighlightField() function.
                 Command line is like this
                 hiHighlightField( Form->TabField->TabName 'Field 2 )
                 As per the intention, Field is hightlighted if the input is wrong, but i am getting an error in CIW as follows
                                     *Error* eval: not a function - 'Field
                                     *Error* car: Can't take car of atom - ERROR
                Can anyone let me know what I am missing here
Thanks and Regards,
Manikandan Kuzandhaivelu
  • skillUser
    skillUser over 11 years ago
    Hi Manikandan,
    Take a look at my code example in this post which shows the use of the hiHighlightField() function.
    Hopefully this will help you,
    Lawrence.
  • Manikk0501
    Hi Lawrence,
                    Thanks for the help. I implemented the 'hiHighlightField()' in a way similar to that in the example which you gave me. Even after that i am getting the following error. I am attaching the snippet of the code i wrote:-
    *Error* eval: not a function - 'cellL
    CODE SNIPPET:-
    t_libL   = r_Form->TabField->page1->libraryL->value
    t_cellL = r_Form->TabField->page1->cellL->value
    if( ddGetObj( t_libL t_cellL ) then
      hiHighlightField(r_Form 'cellL 0)
    else
      hiHighlightField(r_Form 'cellL 1)
    ) ; if
    Thanks and Regards,
    Manikandan, can you email me the entire code? I can't see why it should give this error as there's nothing in your snippet which should suggest that. I do think that your calls to hiHighlightField should have rForm->TabField->page1 as the first argument rather than rForm, but wouldn't expect (without trying it) that this would lead to that error. Kind Regards (and apologies for not answering last week as I had a busy work week and was away), Andrew
    For anyone interested in the problem...
    From having seen the whole code, the issue was not with hiHighlightField() at all, but in the specification of the ?modifyCallback. The expectation is that ?modifyCallback is the name of the function, not a complete expression - and "hi" will add the arguments to the function call itself. If you specify a complete expression, the arguments will still be added, but these arguments will end up being seen as a second function call, with the name of the function being the quoted field name - hence the error.
    Unfortunately this shows that seeing the whole code is often important to understand bugs - they're not always where you might think they are...
  • suzzi
    suzzi over 11 years ago
    I want to dynamically trigger the addition of new fields in a MultiTab GUI through hiAddFields() SKILL command. How should i give the Form name argument in this case since i want one of the Tab to get updated?duvet sets uk
  • Manikk0501
    You can provide like this
    hiAddFields(YourForm->TabFieldName->page l_FieldsToBeAdded)
    w.r.t to the snippet i gave above, it can be coded as
    hiAddFields(r_Form->TabField->page1 l_FieldsToBeAdded)
    where 'TabField' is the tabField I created inside the Form r_Form
    Thanks and Regards,
    Manikandan,
    The post to which you replied is a thinly disguised spam post (they've clearly just taken some text from elsewhere and posted them onto some other vaguely relevant thread, with a link to promote sales of a product). So these posts are being deleted...
