  3. Traversing a Schematic hierarchy and applying selective...
  • Subscribers 150
  • Views 17210
Traversing a Schematic hierarchy and applying selective changes (BASIC questions inside)
Michele Ancis
Michele Ancis over 11 years ago
Hi All,
I am trying to get some leverage from automation of some tasks on my database.
My aim is to write some simple and compact code to "scan" a given hierarchy - in schematic - and be
then able to perform selective changes on some of the cells (or shall I say cellviews? It is actually schematics only) based on different criteria such as
- cellName
- baseName
- specific CDF properties
I think I have got some bits and pieces from my search on this Forum, however still the complete
picture is missing, and I was not able to achieve that by reading the manuals. To me, as a newbie to this, they
look too scattered and I am always missing the next bit. So I hope you can help me with that.
What I gathered so far
http://community.cadence.com/cadence_technology_forums/f/48/p/23100/1313083#1313083
If you select something from a Schematic window, the code:
x=car(GetSelectedSet())
will give you a handle (ObjectID) to what you have selected, and if this is an "inst" you can then access the set of CDF properties through:
CDF = cdfGetInstCDF(x)
at this point, you are able to check/modify many properties including widths, layers, fingers,...This seems OK
http://community.cadence.com/cadence_technology_forums/f/48/t/26388
once you have a cellview handle, you can set up a recursive procedure visiting each instance contained in that cellview.
You can then decide what to do with that specific instance you are visiting, like change some properties if its baseName matches
your query, or whatever else.
The function suggested for getting the first handle, that to the cellview, is asiGetTopCellView(currentSession), thus requiring a
currentSession=asiGetSession(hiGetCurrentWindow())
beforehand.
What I would like to know better
I am looking for something more flexible, where I can give the name of the "topCellView" in different ways, for instance:
 - performing a selection on a schematic window (i.e of a cell within some schematic)
 - inputting a library/cell name combination
I was not able to find a way to accomplish this...Maybe I am looking at the problem from the wrong side...
Specifically, I found no way to get the ddId of a library, which may be the right starting point to input a cell from there (I assume
one could reference, from the "object library X", the different cells which come in it).
I found that if you look at the object returned by
tt=geGetEditCellView()
having previously selected a schematic window of your cell of interest,
there is a property of the cellView called "lib" bearing a dd number, which I assume to be the lib ddID:
tt~>??
However if I try dbAllCellViews(0x1b232568 "MY_CELL_NAME") I get an "invalid library ID" type of response....What am I missing here?
I think I could probably perform a series of cdr(tt) until I finally get to the handle I am interested in, but I am sure there is a more elegant way.
In conclusion
As you see I am pretty scattered around, without a clear picture of where are the elements I need to perform this task, really.
Simple things like how to reference (get the ID for) a cell, a cellView, a library. This, by selection, or by "name".
I do not want to really go deep in SKILL and I do not think that the task I have in mind is difficult, so probably with the right hints
you would get me on the path reasonably soon...
Any pointers to concepts, solutions, specific parts of a manual I should read are greatly appreciated!!
Thank you in advance,
Michele
  • Michele Ancis
    ...And if I just waited a little bit...I found in the Cadence Design Framework II SKILL Functions Reference
    the first bit of my "solution". The way to open a cellView from the name of a library and cell is to use:
    dbOpenCellViewByType()
    OK, that's nice :-)
    M
    P.S. any un-cluttering action from your side is still highly sought after!
  • skillUser
    skillUser over 11 years ago
    Michele,
    You can't 'enter' a dd or db ID as input to another SKILL command, these need to be passed either using variables, or the return value of the appropriate function directly, for example:
    dbAllCellViews(ddGetObj("myLib") "")
    => ("play" "test" ...
    The ddGetObj() function is useful for testing to see if a cellview might exist, you can pass it just a library (as above) or add the cell name, and even provide a specific view name - use this to test for the existence before calling dbOpenCellViewByType() to avoid possible warnings about the cellview not existing...
    Hope this helps!
    Lawrence.
  • Michele Ancis
    ...And thanks again Lawrence!
  • lrlsk
    lrlsk over 11 years ago
    Hi Michele,
    I am not sure about this but I think there is no Non-HI mode equivalent for schHiDescend or similar functions.
    maybe you can traverse all the instances in your current cellview cv~>instances, then open each one by dbOpenCellView..... and apply the selective changes you want.
    BR ~lrlsk
