  3. How to flatten mosaic?
  • Subscribers 150
  • Views 17739
archive over 20 years ago
I'd like flatten all instances including mosaic in current cellview(layout).
I have used skill code such like follows.
A = hiGetCurrentWindow()->cellView
B = A->instances
foreach(C B dbFlattenInst(C 32 t nil nil))
*Error* dbFlattenInst: invalid instId or mosaicId - db:64685232
If I delete mosaic(db:64685232), everything is ok.
How to solve this problem?
I strong guess that "dbFlattenInst" can not flatten mosaic.
Originally posted in cdnusers.org by BAEK
    Baek,
    For the mosaic instance to be flattened, one needs to pass the mosaicId instead of the instanceID to the leFlattenInst command.
    Something like the following (from sourcelink solution 11186852) will work:
    procedure( CCSleFlattenInst(libName cellName )
      let( (cv topInstList )
          if( ddGetObj( libName cellName "layout" ) then
          cv = dbOpenCellViewByType( libName cellName "layout" "maskLayout" "a")
          ;open the layout in non graphical mode
        topInstList = cv~>instances
        ;get a list of all instances in the cellview
    foreach(inst topInstList
         if(inst~>mosaic  then
          leFlattenInst( inst~>mosaic 31 t nil nil )
        ;flatten the mosaic instance
           );if
    leFlattenInst( inst 31 t nil nil )
    ;if it is not a  mosaic flatten with this code
       );foreach
         ;dbSave(cv)   ;optional save command
           ;dbClose(cv)  ;optional close command
          );let
    );procedure
    Originally posted in cdnusers.org by lindam
