  3. reading classes directly from display.drf
  • Views 16434
knuhcrek
knuhcrek over 11 years ago
Greetings all,
using drLoadDrf( newdrf  nil ) seems to merge the contents of newdrf  with the display.drf associated with the design at startup of virtuoso.
Is there a way to read newdrf  so I can access drDefinePacket directly?  drDefinePacket looks like a data structure -- is it  a SKILL++ class?
Chris Walters
rusty former Allegro SKILL guru
  • skillUser
    skillUser over 11 years ago
    Hi Chris,
    If you don't want to load the file but read it instead, you might try something like this...
    fptr = infile("<path_to_display.drf")
    => port:"<path_to_display.drf"
    data = nil
    while(car(data) != 'drDefinePacket
      data = read(fptr)
    ;; check to see if the data is really there
    car(data)
    => drDefinePacket
    ;; find "M2_drawing" packet, for example
    car(setof(pack cdr(data) eq('M2_drawing cadr(pack)))
    => (display M2_drawing slash solid gold gold outlineStipple)
    Hopefully you get the idea and this is helpful to you?
    Lawrence.
  • knuhcrek
    I'll give this a whirl, thanks for your response.
