  3. PGable Text
  • Views 18385
PGable Text
archive over 20 years ago
I am in need of a skill function to create maskable text for rev letters etc.  I looked on the comp.cad.cadence google group and something called pgtext.il was mentioned but no code was forthcoming.  Any help would be appreciated.
Originally posted in cdnusers.org by CollinWeiss
    Here is the code that was given to me:
    Program Name    : cr_pgText.il
    cr_pgText is a program to create text that can be used for pattern
    generation. This is accomplished by drawing each character as
    a polygon.  The program will prompt for a text string. The
    text string can contain any charater that is defined by
    symbol as described below and spaces. The program will then draw
    the polygons on the user specified layer. Presently, the text patterns
    are generated on the 'drawing' purpose only.
    procedure(cr_pgText()
        let((snapMode snapeShape text_string magAmount mtextString mSpaceBetween userGrid)
        userGrid = leDisplayOptionsForm->xSnap->value
        printf("Character input is case insensitive but output will be UPPER CASE\n")
        printf("Any Integer May Be Used With The Following Grids: (x/y Snap)\n")
        printf("Multiples of 20 - Use Grid (x/y Snap of 1.0)\n")
        printf("Multiples of 10 - Use Grid (x/y Snap of 0.5)\n")
        printf("Multiples of  5 - Use Grid (x/y Snap of 0.25)\n")
        printf("Even Multiples Other Than Above - Use a Grid (x/y Snap) of 0.1\n")
        printf("Odd Multiples Other Than Above - Use a Grid (x/y Snap) of 0.05\n")
        printf("Other Grids May Result In Line Mismatch\n")
        cr_pgTextForm()
    procedure( cr_pgTextForm()
        (text_string = (hiCreateStringField ?name
            'text_string ?prompt "Enter Text"
            ?value "" ?defValue "" ?callback
            "" ?editable t
        (magAmount = (hiCreateStringField ?name
            'magAmount ?prompt "Enter Mag"
            "" ?editable t
        (layerField = hiCreateLayerCyclicField(
                    techGetTechFile(geGetEditCellView())
            "Layer for Polygon Text"
                    nil
                    (if boundp('cr_pgMLayer) list(cr_pgMLayer "drawing") leGetEntryLayer() )
        (formId = (hiCreateForm
            'cr_pgTextForm "Programmable Text Generator" "cr_pgTextCB()"
            list(text_string magAmount layerField)
        hiDisplayForm(formId)
    procedure(cr_pgTextCB()
        (text_string = stringToLower( ((cr_pgTextForm->text_string)->value)) )
        cr_pgMLayer = hiLayerStringToLPP(
                   cadddr(cr_pgTextForm-> hiLayerField->value))~>name
        printf("cr_pgMLayer set to ")
            println(cr_pgMLayer)
        (magAmount = float(evalstring(((cr_pgTextForm->magAmount)->value))))
        (dspace = 2)
        (sspace = 5.000000)
        (pntr = 0)
        (mtextString = parseString(text_string "" ))
        (characterWidth = "norm")
        foreach( character mtextString
            case( characterWidth
            ("norm"
                (pntr = (pntr + (magAmount * dspace))))
            ("wide"
                (pntr = (pntr + (magAmount * dspace * 1.200000))))
            ("narrow"
                (pntr = (pntr + (magAmount * dspace * 0.600000))))
            case( character
            ("m"
                (characterWidth = "wide"))
            ("w"
            (("i" "'" ":" ";" "(" ")" "!" "." "[" "]" "1" "\"")
                (characterWidth = "narrow"))
            (t
                (characterWidth = "norm"))
            ;printf("drawing character %s\n" character)
            case( character
               ; println("added space character")
            ("a"
                (dbCreatePolygon
                getEditRep()  cr_pgMLayer
                modifyCoords(coords_listAMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listAMS2 pntr magAmount)
            ("b"
                (dbCreatePolygon
                modifyCoords(coords_listBMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listBMS2 pntr magAmount)
            ("c"
                (dbCreatePolygon
                modifyCoords(coords_listCMS pntr magAmount)
            ("d"
                (dbCreatePolygon
                modifyCoords(coords_listDMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listDMS1 pntr magAmount)
            ("e"
                (dbCreatePolygon
                modifyCoords(coords_listEMS pntr magAmount)
            ("f"
                (dbCreatePolygon
                modifyCoords(coords_listFMS pntr magAmount)
            ("g"
                (dbCreatePolygon
                modifyCoords(coords_listGMS pntr magAmount)
            ("h"
                (dbCreatePolygon
                modifyCoords(coords_listHMS pntr magAmount)
            ("i"
                (dbCreatePolygon
                modifyCoords(coords_listIMS pntr magAmount)
            ("j"
                (dbCreatePolygon
                modifyCoords(coords_listJMS pntr magAmount)
            ("k"
                (dbCreatePolygon
                modifyCoords(coords_listKMS pntr magAmount)
            ("l"
                (dbCreatePolygon
                modifyCoords(coords_listLMS pntr magAmount)
            ("m"
                (dbCreatePolygon
                modifyCoords(coords_listMMS pntr magAmount)
            ("n"
                (dbCreatePolygon
                modifyCoords(coords_listNMS pntr magAmount)
            ("o"
                (dbCreatePolygon
                modifyCoords(coords_listOMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listOMS1 pntr magAmount)
            ("p"
                (dbCreatePolygon
                modifyCoords(coords_listPMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPMS1 pntr magAmount)
            ("q"
                (dbCreatePolygon
                modifyCoords(coords_listQMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listQMS1 pntr magAmount)
            ("r"
                (dbCreatePolygon
                modifyCoords(coords_listRMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listRMS1 pntr magAmount)
            ("s"
                (dbCreatePolygon
                modifyCoords(coords_listSMS pntr magAmount)
            ("t"
                (dbCreatePolygon
                modifyCoords(coords_listTMS pntr magAmount)
            ("u"
                (dbCreatePolygon
                modifyCoords(coords_listUMS pntr magAmount)
            ("v"
                (dbCreatePolygon
                modifyCoords(coords_listVMS pntr magAmount)
            ("w"
                (dbCreatePolygon
                modifyCoords(coords_listWMS pntr magAmount)
            ("x"
                (dbCreatePolygon
                modifyCoords(coords_listXMS pntr magAmount)
            ("y"
                (dbCreatePolygon
                modifyCoords(coords_listYMS pntr magAmount)
            ("z"
                (dbCreatePolygon
                modifyCoords(coords_listZMS pntr magAmount)
            ("0"
                (dbCreatePolygon
                modifyCoords(coords_listMS0 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listMS01 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listMS02 pntr magAmount)
            ("1"
                (dbCreatePolygon
                modifyCoords(coords_listMS1 pntr magAmount)
            ("2"
                (dbCreatePolygon
                modifyCoords(coords_listMS2 pntr magAmount)
            ("3"
                (dbCreatePolygon
                modifyCoords(coords_listMS3 pntr magAmount)
            ("4"
                (dbCreatePolygon
                modifyCoords(coords_listMS4 pntr magAmount)
            ("5"
                (dbCreatePolygon
                modifyCoords(coords_listMS5 pntr magAmount)
            ("6"
                (dbCreatePolygon
                modifyCoords(coords_listMS6 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listMS61 pntr magAmount)
            ("7"
                (dbCreatePolygon
                modifyCoords(coords_listMS7 pntr magAmount)
            ("8"
                (dbCreatePolygon
                modifyCoords(coords_listMS8 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listMS81 pntr magAmount)
            ("9"
                (dbCreatePolygon
                modifyCoords(coords_listMS9 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listMS91 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPERMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listCOMMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listDASMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listSLMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listEXMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listEXMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listQMMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listQMMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listCOLMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listCOLMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listSCMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listSCMS1 pntr magAmount)
            ("_"
                (dbCreatePolygon
                modifyCoords(coords_listUSMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listEQMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listEQMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPLUMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listASTMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listAPMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listLPMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listRPMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listLBMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listRBMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listBSMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listQUMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listQUMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPCTMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPCTMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listPCTMS2 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listDSMS pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listDSMS1 pntr magAmount)
                (dbCreatePolygon
                modifyCoords(coords_listDSMS2 pntr magAmount)
                    (t printf("The '%s' character is not supported by cr_pgText.\n" character)
                       printf("Skipping the '%s' character and leaving space for the user to insert it.\n" character)
            );end case
    procedure( modifyCoords(wholelist pntrNum magAmount)
        prog( nil
        (newwholelist = list())
        (finalnewwholelist = list())
        foreach( sublistm wholelist
            (xnumberm =
            (pntrNum + ((car(sublistm) * magAmount * 1000.000000) / 1000.000000)))
            (ynumberm = ((cadr(sublistm) * magAmount * 1000.000000) / 1000.000000))
            (newsublistm = geWindowToEditPoint(getCurrentWindow()
                               list(xnumberm ynumberm))
            (newwholelist = xcons(newwholelist newsublistm))
            (finalnewwholelist = reverse(newwholelist))
            (newsublistm = nil)
        return(finalnewwholelist)
    ;coords data
        (coords_listAMS1 = list((0.800000:0.600000)
            (0.800000:1.000000)
            (0.400000:1.000000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.600000)
            (0.800000:0.600000)
        (coords_listAMS2 = list((0.800000:0.600000)
            (1.200000:0.600000)
            (1.200000:0.0)
            (1.600000:0.0)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.200000:1.000000)
            (0.800000:1.000000)
            (0.800000:0.600000)
        (coords_listBMS1 = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.400000:0.400000)
            (0.400000:0.800000)
            (0.800000:0.800000)
            (0.800000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
            (0.800000:0.0)
        (coords_listBMS2 = list((0.800000:0.0)
            (0.800000:0.400000)
            (1.100000:0.400000)
            (1.200000:0.500000)
            (1.200000:0.700000)
            (1.100000:0.800000)
            (0.800000:0.800000)
            (0.800000:1.200000)
            (1.100000:1.200000)
            (1.200000:1.300000)
            (1.200000:1.500000)
            (1.100000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (1.300000:2.000000)
            (1.600000:1.700000)
            (1.600000:1.200000)
            (1.400000:1.000000)
            (1.600000:0.800000)
            (1.600000:0.300000)
            (1.300000:0.0)
            (0.800000:0.0)
        (coords_listCMS = list((0.0:0.400000)
            (0.400000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:0.600000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.600000:1.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.400000)
        (coords_listDMS = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.400000:0.400000)
            (0.400000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
            (0.800000:0.0)
        (coords_listDMS1 = list((0.800000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listEMS = list((0.0:0.0)
            (1.600000:0.0)
            (1.600000:0.400000)
            (0.400000:0.400000)
            (0.400000:0.800000)
            (1.200000:0.800000)
            (1.200000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.600000)
            (1.600000:1.600000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listFMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.800000)
            (1.200000:0.800000)
            (1.200000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.600000)
            (1.600000:1.600000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listGMS = list((0.400000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:1.000000)
            (0.800000:1.000000)
            (0.800000:0.700000)
            (1.200000:0.700000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.600000:1.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.400000)
            (0.400000:0.0)
        (coords_listHMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.800000)
            (1.200000:0.800000)
            (1.200000:0.0)
            (1.600000:0.0)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:1.200000)
            (0.400000:1.200000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listIMS = list((0.0:0.0)
            (0.800000:0.0)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.600000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.0:2.000000)
            (0.0:1.600000)
            (0.200000:1.600000)
            (0.200000:0.400000)
            (0.0:0.400000)
            (0.0:0.0)
        (coords_listJMS = list((0.400000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:0.700000)
            (0.0:0.700000)
            (0.0:0.400000)
            (0.400000:0.0)
        (coords_listKMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.800000)
            (0.600000:0.800000)
            (1.200000:0.200000)
            (1.200000:0.0)
            (1.600000:0.0)
            (1.600000:0.400000)
            (1.000000:1.000000)
            (1.600000:1.600000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:1.800000)
            (0.600000:1.200000)
            (0.400000:1.200000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listLMS = list((0.0:0.0)
            (1.600000:0.0)
            (1.600000:0.400000)
            (0.400000:0.400000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listMMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:1.200000)
            (0.600000:1.200000)
            (1.000000:0.800000)
            (1.400000:1.200000)
            (1.600000:1.200000)
            (1.600000:0.0)
            (2.000000:0.0)
            (2.000000:2.000000)
            (1.600000:2.000000)
            (1.000000:1.400000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listNMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:1.000000)
            (0.500000:1.000000)
            (1.500000:0.0)
            (1.600000:0.0)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:1.000000)
            (1.100000:1.000000)
            (0.100000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listOMS = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.400000)
            (0.400000:0.0)
            (0.800000:0.0)
        (coords_listOMS1 = list((0.800000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listPMS = list((0.800000:0.800000)
            (0.800000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.800000)
            (0.800000:0.800000)
        (coords_listPMS1 = list((0.800000:0.800000)
            (1.300000:0.800000)
            (1.600000:1.100000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.300000)
            (1.100000:1.200000)
            (0.800000:1.200000)
            (0.800000:0.800000)
        (coords_listQMS = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.400000)
            (0.400000:0.0)
            (0.800000:0.0)
        (coords_listQMS1 = list((0.800000:0.0)
            (1.200000:0.0)
            (1.400000:-0.200000)
            (1.800000:0.200000)
            (1.600000:0.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listRMS = list((0.600000:0.800000)
            (0.600000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.600000)
            (0.600000:1.600000)
            (0.600000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.800000)
            (0.600000:0.800000)
        (coords_listRMS1 = list((0.600000:0.800000)
            (0.800000:0.800000)
            (1.200000:0.400000)
            (1.200000:0.0)
            (1.600000:0.0)
            (1.600000:0.500000)
            (1.300000:0.800000)
            (1.600000:1.100000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.600000:2.000000)
            (0.600000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.300000)
            (1.100000:1.200000)
            (0.600000:1.200000)
            (0.600000:0.800000)
        (coords_listSMS = list((0.300000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:0.900000)
            (1.300000:1.200000)
            (0.500000:1.200000)
            (0.400000:1.300000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.600000:1.500000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.100000)
            (0.300000:0.800000)
            (1.100000:0.800000)
            (1.200000:0.700000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.0:0.500000)
            (0.0:0.300000)
            (0.300000:0.0)
        (coords_listTMS = list((0.600000:0.0)
            (1.000000:0.0)
            (1.000000:1.600000)
            (1.600000:1.600000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:1.600000)
            (0.600000:1.600000)
            (0.600000:0.0)
        (coords_listUMS = list((0.400000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.400000)
            (0.400000:0.0)
        (coords_listVMS = list((0.700000:0.0)
            (0.900000:0.0)
            (1.600000:0.700000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:0.900000)
            (0.800000:0.500000)
            (0.400000:0.900000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.700000)
            (0.700000:0.0)
        (coords_listWMS = list((0.0:0.0)
            (0.400000:0.0)
            (1.000000:0.600000)
            (1.600000:0.0)
            (2.000000:0.0)
            (2.000000:2.000000)
            (1.600000:2.000000)
            (1.600000:0.800000)
            (1.400000:0.800000)
            (1.000000:1.200000)
            (0.600000:0.800000)
            (0.400000:0.800000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.0)
        (coords_listXMS = list((0.0:0.0)
            (0.400000:0.0)
            (0.400000:0.400000)
            (0.800000:0.800000)
            (1.200000:0.400000)
            (1.200000:0.0)
            (1.600000:0.0)
            (1.600000:0.600000)
            (1.200000:1.000000)
            (1.600000:1.400000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:1.600000)
            (0.800000:1.200000)
            (0.400000:1.600000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:1.400000)
            (0.400000:1.000000)
            (0.0:0.600000)
            (0.0:0.0)
        (coords_listYMS = list((0.600000:0.0)
            (1.000000:0.0)
            (1.000000:0.700000)
            (1.600000:1.300000)
            (1.600000:2.000000)
            (1.200000:2.000000)
            (1.200000:1.500000)
            (0.800000:1.100000)
            (0.400000:1.500000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:1.300000)
            (0.600000:0.700000)
            (0.600000:0.0)
        (coords_listZMS = list((0.0:0.0)
            (1.600000:0.0)
            (1.600000:0.400000)
            (0.600000:0.400000)
            (0.600000:0.500000)
            (1.600000:1.500000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:1.600000)
            (1.000000:1.600000)
            (1.000000:1.500000)
            (0.0:0.500000)
            (0.0:0.0)
        (coords_listMS0 = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.400000:0.600000)
            (0.400000:1.400000)
            (0.600000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.400000:2.000000)
            (0.0:1.600000)
            (0.0:0.400000)
            (0.400000:0.0)
            (0.800000:0.0)
        (coords_listMS01 = list((0.800000:0.0)
            (1.200000:0.0)
            (1.600000:0.400000)
            (1.600000:1.600000)
            (1.200000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.000000:1.600000)
            (1.200000:1.400000)
            (1.200000:0.600000)
            (1.000000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listMS02 = list((0.700000:0.700000)
            (1.100000:1.100000)
            (0.900000:1.300000)
            (0.500000:0.900000)
            (0.700000:0.700000)
        (coords_listMS1 = list((0.0:0.0)
            (0.800000:0.0)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.600000:2.000000)
            (0.200000:2.000000)
            (0.0:1.800000)
            (0.0:1.600000)
            (0.200000:1.600000)
            (0.200000:0.400000)
            (0.0:0.400000)
            (0.0:0.0)
        (coords_listMS2 = list((0.0:0.0)
            (1.600000:0.0)
            (1.600000:0.400000)
            (0.400000:0.400000)
            (0.400000:0.600000)
            (0.500000:0.700000)
            (1.300000:0.700000)
            (1.600000:1.000000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.500000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.200000)
            (1.100000:1.100000)
            (0.300000:1.100000)
            (0.0:0.800000)
            (0.0:0.0)
        (coords_listMS3 = list((0.300000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:0.800000)
            (1.400000:1.000000)
            (1.600000:1.200000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.500000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.300000)
            (1.100000:1.200000)
            (0.700000:1.200000)
            (0.700000:0.800000)
            (1.100000:0.800000)
            (1.200000:0.700000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.0:0.500000)
            (0.0:0.300000)
            (0.300000:0.0)
        (coords_listMS4 = list((0.0:0.800000)
            (1.000000:0.800000)
            (1.000000:0.0)
            (1.400000:0.0)
            (1.400000:0.800000)
            (1.600000:0.800000)
            (1.600000:1.200000)
            (1.400000:1.200000)
            (1.400000:2.000000)
            (1.000000:2.000000)
            (1.000000:1.200000)
            (0.400000:1.200000)
            (0.400000:2.000000)
            (0.0:2.000000)
            (0.0:0.800000)
        (coords_listMS5 = list((0.300000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:1.000000)
            (1.300000:1.300000)
            (0.500000:1.300000)
            (0.400000:1.400000)
            (0.400000:1.600000)
            (1.600000:1.600000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:1.200000)
            (0.300000:0.900000)
            (1.100000:0.900000)
            (1.200000:0.800000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.0:0.500000)
            (0.0:0.300000)
            (0.300000:0.0)
        (coords_listMS6 = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.400000:0.700000)
            (0.500000:0.800000)
            (0.800000:0.800000)
            (0.800000:1.200000)
            (0.400000:1.200000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.600000:1.500000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:0.300000)
            (0.300000:0.0)
            (0.800000:0.0)
        (coords_listMS61 = list((0.800000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:0.900000)
            (1.300000:1.200000)
            (0.800000:1.200000)
            (0.800000:0.800000)
            (1.100000:0.800000)
            (1.200000:0.700000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listMS7 = list((0.600000:0.0)
            (1.000000:0.0)
            (1.000000:0.800000)
            (1.600000:1.400000)
            (1.600000:2.000000)
            (0.0:2.000000)
            (0.0:1.600000)
            (1.200000:1.600000)
            (1.200000:1.500000)
            (0.600000:0.900000)
            (0.600000:0.0)
        (coords_listMS8 = list((0.800000:0.0)
            (0.800000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.400000:0.700000)
            (0.500000:0.800000)
            (0.800000:0.800000)
            (0.800000:1.200000)
            (0.500000:1.200000)
            (0.400000:1.300000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (0.800000:1.600000)
            (0.800000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.200000)
            (0.200000:1.000000)
            (0.0:0.800000)
            (0.0:0.300000)
            (0.300000:0.0)
            (0.800000:0.0)
        (coords_listMS81 = list((0.800000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:0.800000)
            (1.400000:1.000000)
            (1.600000:1.200000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.300000)
            (1.100000:1.200000)
            (0.800000:1.200000)
            (0.800000:0.800000)
            (1.100000:0.800000)
            (1.200000:0.700000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.800000:0.400000)
            (0.800000:0.0)
        (coords_listMS9 = list((0.800000:1.600000)
            (0.800000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.100000)
            (0.300000:0.800000)
            (0.800000:0.800000)
            (0.800000:1.200000)
            (0.500000:1.200000)
            (0.400000:1.300000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (0.800000:1.600000)
        (coords_listMS91 = list((0.800000:1.600000)
            (1.100000:1.600000)
            (1.200000:1.500000)
            (1.200000:1.300000)
            (1.100000:1.200000)
            (0.800000:1.200000)
            (0.800000:0.800000)
            (1.200000:0.800000)
            (1.200000:0.500000)
            (1.100000:0.400000)
            (0.500000:0.400000)
            (0.400000:0.500000)
            (0.0:0.500000)
            (0.0:0.300000)
            (0.300000:0.0)
            (1.300000:0.0)
            (1.600000:0.300000)
            (1.600000:1.700000)
            (1.300000:2.000000)
            (0.800000:2.000000)
            (0.800000:1.600000)
        (coords_listPERMS = list((0.100000:0.100000)
            (0.300000:0.100000)
            (0.400000:0.200000)
            (0.400000:0.400000)
            (0.300000:0.500000)
            (0.100000:0.500000)
            (0.0:0.400000)
            (0.0:0.200000)
            (0.100000:0.100000)
        (coords_listCOMMS = list((0.100000:0.100000)
            (-0.100000:-0.100000)
            (0.0:-0.200000)
            (0.400000:0.200000)
            (0.400000:0.400000)
            (0.300000:0.500000)
            (0.100000:0.500000)
            (0.0:0.400000)
            (0.0:0.200000)
            (0.100000:0.100000)
        (coords_listDASMS = list((0.0:0.900000)
            (1.600000:0.900000)
            (1.600000:1.200000)
            (0.0:1.200000)
            (0.0:0.900000)
        (coords_listSLMS = list((0.200000:0.200000)
            (1.600000:1.600000)
            (1.400000:1.800000)
            (0.0:0.400000)
            (0.200000:0.200000)
        (coords_listEXMS = list((0.100000:0.800000)
            (0.300000:0.800000)
            (0.400000:0.900000)
            (0.400000:1.900000)
            (0.300000:2.000000)
            (0.100000:2.000000)
            (0.0:1.900000)
            (0.0:0.900000)
            (0.100000:0.800000)
        (coords_listEXMS1 = list((0.100000:0.0)
            (0.300000:0.0)
            (0.400000:0.100000)
            (0.400000:0.300000)
            (0.300000:0.400000)
            (0.100000:0.400000)
            (0.0:0.300000)
            (0.0:0.100000)
            (0.100000:0.0)
        (coords_listQMMS = list((0.500000:0.600000)
            (0.900000:0.600000)
            (1.000000:0.700000)
            (1.200000:0.700000)
            (1.500000:1.000000)
            (1.500000:1.700000)
            (1.200000:2.000000)
            (0.300000:2.000000)
            (0.0:1.700000)
            (0.0:1.400000)
            (0.400000:1.400000)
            (0.400000:1.500000)
            (0.500000:1.600000)
            (1.000000:1.600000)
            (1.100000:1.500000)
            (1.100000:1.200000)
            (1.000000:1.100000)
            (0.800000:1.100000)
            (0.500000:0.800000)
            (0.500000:0.600000)
        (coords_listQMMS1 = list((0.600000:0.0)
            (0.800000:0.0)
            (0.900000:0.100000)
            (0.900000:0.300000)
            (0.800000:0.400000)
            (0.600000:0.400000)
            (0.500000:0.300000)
            (0.500000:0.100000)
            (0.600000:0.0)
        (coords_listCOLMS = list((0.100000:0.0)
            (0.300000:0.0)
            (0.400000:0.100000)
            (0.400000:0.300000)
            (0.300000:0.400000)
            (0.100000:0.400000)
            (0.0:0.300000)
            (0.0:0.100000)
            (0.100000:0.0)
        (coords_listCOLMS1 = list((0.100000:0.800000)
            (0.300000:0.800000)
            (0.400000:0.900000)
            (0.400000:1.100000)
            (0.300000:1.200000)
            (0.100000:1.200000)
            (0.0:1.100000)
            (0.0:0.900000)
            (0.100000:0.800000)
        (coords_listSCMS = list((0.100000:0.0)
            (-0.100000:-0.200000)
            (0.0:-0.300000)
            (0.400000:0.100000)
            (0.400000:0.300000)
            (0.300000:0.400000)
            (0.100000:0.400000)
            (0.0:0.300000)
            (0.0:0.100000)
            (0.100000:0.0)
        (coords_listSCMS1 = list((0.100000:0.800000)
            (0.300000:0.800000)
            (0.400000:0.900000)
            (0.400000:1.100000)
            (0.300000:1.200000)
            (0.100000:1.200000)
            (0.0:1.100000)
            (0.0:0.900000)
            (0.100000:0.800000)
        (coords_listUSMS = list((0.0:0.0)
            (1.600000:0.0)
            (1.600000:0.300000)
            (0.0:0.300000)
            (0.0:0.0)
        (coords_listEQMS = list((0.0:0.500000)
            (1.400000:0.500000)
            (1.400000:0.800000)
            (0.0:0.800000)
            (0.0:0.500000)
        (coords_listEQMS1 = list((0.0:1.200000)
            (1.400000:1.200000)
            (1.400000:1.500000)
            (0.0:1.500000)
            (0.0:1.200000)
        (coords_listPLUMS = list((0.0:0.900000)
            (0.600000:0.900000)
            (0.600000:0.300000)
            (0.900000:0.300000)
            (0.900000:0.900000)
            (1.500000:0.900000)
            (1.500000:1.200000)
            (0.900000:1.200000)
            (0.900000:1.800000)
            (0.600000:1.800000)
            (0.600000:1.200000)
            (0.0:1.200000)
            (0.0:0.900000)
        (coords_listASTMS = list((0.0:0.900000)
            (0.500000:0.900000)
            (0.100000:0.500000)
            (0.200000:0.400000)
            (0.600000:0.800000)
            (0.600000:0.300000)
            (0.800000:0.300000)
            (0.800000:0.800000)
            (1.200000:0.400000)
            (1.300000:0.500000)
            (0.900000:0.900000)
            (1.400000:0.900000)
            (1.400000:1.100000)
            (0.900000:1.100000)
            (1.300000:1.500000)
            (1.200000:1.600000)
            (0.800000:1.200000)
            (0.800000:1.700000)
            (0.600000:1.700000)
            (0.600000:1.200000)
            (0.200000:1.600000)
            (0.100000:1.500000)
            (0.500000:1.100000)
            (0.0:1.100000)
            (0.0:0.900000)
        (coords_listAPMS = list((0.0:1.700000)
            (0.100000:1.600000)
            (-0.100000:1.400000)
            (0.0:1.300000)
            (0.400000:1.700000)
            (0.400000:1.900000)
            (0.300000:2.000000)
            (0.100000:2.000000)
            (0.0:1.900000)
            (0.0:1.700000)
        (coords_listLPMS = list((0.400000:-0.200000)
            (0.700000:-0.200000)
            (0.700000:0.100000)
            (0.500000:0.100000)
            (0.300000:0.300000)
            (0.300000:1.700000)
            (0.500000:1.900000)
            (0.700000:1.900000)
            (0.700000:2.200000)
            (0.400000:2.200000)
            (0.0:1.800000)
            (0.0:0.200000)
        (coords_listRPMS = list((0.0:-0.200000)
            (0.300000:-0.200000)
            (0.700000:0.200000)
            (0.700000:1.800000)
            (0.300000:2.200000)
            (0.0:2.200000)
            (0.0:1.900000)
            (0.200000:1.900000)
            (0.400000:1.700000)
            (0.400000:0.300000)
            (0.200000:0.100000)
            (0.0:0.100000)
            (0.0:-0.200000)
        (coords_listLBMS = list((0.0:-0.200000)
            (0.700000:0.100000)
            (0.300000:0.100000)
            (0.300000:1.900000)
            (0.700000:1.900000)
            (0.700000:2.200000)
            (0.0:2.200000)
            (0.0:-0.200000)
        (coords_listRBMS = list((0.0:-0.200000)
            (0.700000:2.200000)
            (0.0:2.200000)
            (0.0:1.900000)
            (0.400000:1.900000)
            (0.400000:0.100000)
            (0.0:0.100000)
            (0.0:-0.200000)
        (coords_listBSMS = list((1.400000:0.200000)
            (1.600000:0.400000)
            (0.200000:1.800000)
            (0.0:1.600000)
            (1.400000:0.200000)
        (coords_listQUMS = list((0.0:1.400000)
            (0.300000:1.400000)
            (0.300000:2.200000)
            (0.0:2.200000)
            (0.0:1.400000)
        (coords_listQUMS1 = list((0.600000:1.400000)
            (0.900000:1.400000)
            (0.900000:2.200000)
            (0.600000:2.200000)
            (0.600000:1.400000)
        (coords_listPCTMS = list((0.200000:0.200000)
            (1.600000:1.600000)
            (1.400000:1.800000)
            (0.0:0.400000)
            (0.200000:0.200000)
        (coords_listPCTMS1 = list((0.100000:1.400000)
            (0.300000:1.400000)
            (0.400000:1.500000)
            (0.400000:1.700000)
            (0.300000:1.800000)
            (0.100000:1.800000)
            (0.0:1.700000)
            (0.0:1.500000)
            (0.100000:1.400000)
        (coords_listPCTMS2 = list((1.300000:0.200000)
            (1.500000:0.200000)
            (1.600000:0.300000)
            (1.600000:0.500000)
            (1.500000:0.600000)
            (1.300000:0.600000)
            (1.200000:0.500000)
            (1.200000:0.300000)
            (1.300000:0.200000)
        (coords_listDSMS = list((0.0:1.400000)
            (0.200000:1.400000)
            (0.200000:1.700000)
            (0.300000:1.800000)
            (0.700000:1.800000)
            (0.700000:1.400000)
            (0.900000:1.400000)
            (0.900000:1.800000)
            (1.300000:1.800000)
            (1.400000:1.700000)
            (1.600000:1.700000)
            (1.600000:1.800000)
            (1.400000:2.000000)
            (0.900000:2.000000)
            (0.900000:2.200000)
            (0.700000:2.200000)
            (0.700000:2.000000)
            (0.200000:2.000000)
            (0.0:1.800000)
            (0.0:1.400000)
        (coords_listDSMS1 = list((0.0:1.400000)
            (0.0:1.100000)
            (0.200000:0.900000)
            (0.700000:0.900000)
            (0.700000:0.600000)
            (0.900000:0.600000)
            (0.900000:0.900000)
            (1.300000:0.900000)
            (1.400000:0.800000)
            (1.400000:0.600000)
            (1.600000:0.600000)
            (1.600000:0.900000)
            (1.400000:1.100000)
            (0.900000:1.100000)
            (0.900000:1.400000)
            (0.700000:1.400000)
            (0.700000:1.100000)
            (0.300000:1.100000)
            (0.200000:1.200000)
            (0.200000:1.400000)
            (0.0:1.400000)
        (coords_listDSMS2 = list((0.200000:0.0)
            (0.700000:0.0)
            (0.900000:-0.200000)
            (0.900000:0.0)
            (1.400000:0.0)
            (1.600000:0.200000)
            (1.600000:0.600000)
            (1.400000:0.600000)
            (1.400000:0.300000)
            (1.300000:0.200000)
            (0.900000:0.200000)
            (0.900000:0.600000)
            (0.700000:0.600000)
            (0.700000:0.200000)
            (0.300000:0.200000)
            (0.200000:0.300000)
            (0.0:0.300000)
            (0.0:0.200000)
            (0.200000:0.0)
    or try this one :
    *  DISCLAIMER: The following code is provided for Cadence customers to use at  *
    *   their own risk. The code may require modification to satisfy the           *
    *   requirements of any user. The code and any modifications to the code may   *
    *   not be compatible with current or future versions of Cadence products.     *
    *   THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT     *
    *   LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    *   OR FITNESS FOR A PARTICULAR USE.
         Function Name :    PGtext
         Title         :    Yet another pg-able text routine.
         Synopsis      :    PGtext() => nil
         Users guide   :    None
         Description   :
         ; PGtext is a program to create text that can be used
         ; for pattern generation of MEBES lithography. This is
         ; accomplished by drawing each character as a polygon.
         ; The program will prompt for a text string. The text
         ; string can contain any character that is defined by
         ; symbol as described below and spaces. The program
         ; will then draw the polygons on the current layer.
         ; The coordinate information for each of these polygons
         ; is stored as a symbol with the name of character.
         ; As an example a file containing a definition for the
         ; character "A" with the prefix "a_" would be:
         ; a_A=list( (1.000000:0.000000) (1.000000:6.500000) (2.500000:8.000000) (4.500000:8.000000) (6.000000:6.500000) (6.000000:4.000000) (1.000000:4.000000) (1.000000:3.000000) (6.000000:3.000000) (6.000000:0.000000) (7.000000:0.000000) (7.000000:7.000000) (5.000000:9.000000) (2.000000:9.000000) (0.000000:7.000000) (0.000000:0.000000))
         ; Any file containing character definitions must first be loaded.
         ; A program to create this file is provided. See "makeLetter" below.
         ; An example file containing characters a-z,A-Z and 0-9 is
         ; provided with the name "PGtext.il". ( the characters
         ; in this file are 9 units tall)
         ; The prefix is determined by setting the symbol "PGtextPreFix".
         ; A character to character spacing is determined by setting the
         ; symbol "PGtextSpacing". A grid is also specified by setting the
         ; symbol "PGtextGrid". This will force all points to this grid.
         ; PGtext also prompts for a magnification to be applied to the
         ; text. As an example: the character "A" defined above is 9 units
         ; high. If a mag of 2.0 is applied then the resultant polygon
         ; would be 18 units high. This mag is also applied to the text
         ; spacing. PGtext will allways put the text string in with a justification
         ; of lower left with no rotation or reflection. The program will
         ; leave the characters selected so that a orientation can be
         ; acomplished with reguler rotate and reflect commands.
         ; ******  makeLetter  ************
         ; makeLetter will create a definition as described above into the
         ; file defined by setting the variable "PGtextFile". This is done
         ; by first drawing the letter with a single polygon. (only one
         ; polygon can be used and no rectangles!!) Select the polygon
         ; and execute "makeLetter". This program will use the symbol
         ; "PGtextPreFix" and prompt for the character definition. It
         ; will automaticly justify the letter at the lower left extent
         ; of the polygon. (this means lower case letters cannot extend
         ; below the bottom of the line). By changing the "PGtextPreFix"
         ; different fonts can be defined. These programs use a symbol
         ; for each character, therefore only characters valid for "il"
         ; symbol names can be used. (sorry, this was the simplest way for
         ; me to accomplish this program). A space is defined as the
         ; width of the previous character.
         PGtextPreFix="a_"
         PGtextSpacing=1.5
         PGtextGrid=0.25
         PGtextFile="PGtextFile.il"
         a_B=list(  ( 1.000000:0.000000 ) ( 1.000000:8.000000 ) ( 5.250000:8.000000 ) ( 6.000000:7.250000 ) ( 6.000000:5.750000 ) ( 5.250000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:4.000000 ) ( 5.250000:4.000000 ) ( 6.000000:3.250000 ) ( 6.000000:1.750000 ) ( 5.250000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:0.000000 ) ( 5.500000:0.000000 ) ( 7.000000:1.500000 ) ( 7.000000:3.500000 ) ( 6.000000:4.500000 ) ( 7.000000:5.500000 ) ( 7.000000:7.500000 ) ( 5.500000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) )
         a_A=list(  ( 1.000000:0.000000 ) ( 1.000000:6.500000 ) ( 2.500000:8.000000 ) ( 4.500000:8.000000 ) ( 6.000000:6.500000 ) ( 6.000000:4.000000 ) ( 1.000000:4.000000 ) ( 1.000000:3.000000 ) ( 6.000000:3.000000 ) ( 6.000000:0.000000 ) ( 7.000000:0.000000 ) ( 7.000000:7.000000 ) ( 5.000000:9.000000 ) ( 2.000000:9.000000 ) ( 0.000000:7.000000 ) ( 0.000000:0.000000 ) )
         a_C=list(  ( 7.000000:3.000000 ) ( 6.000000:3.000000 ) ( 6.000000:2.500000 ) ( 4.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) ( 1.000000:6.500000 ) ( 2.500000:8.000000 ) ( 4.500000:8.000000 ) ( 6.000000:6.500000 ) ( 6.000000:6.000000 ) ( 7.000000:6.000000 ) ( 7.000000:7.000000 ) ( 5.000000:9.000000 ) ( 2.000000:9.000000 ) ( 0.000000:7.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 5.000000:0.000000 ) ( 7.000000:2.000000 ) )
         a_D=list(  ( 7.000000:7.000000 ) ( 5.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:8.000000 ) ( 4.500000:8.000000 ) ( 6.000000:6.500000 ) ( 6.000000:2.500000 ) ( 4.500000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:0.000000 ) ( 5.000000:0.000000 ) ( 7.000000:2.000000 ) )
         a_E=list(  ( 6.000000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:4.000000 ) ( 4.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:8.000000 ) ( 6.000000:8.000000 ) ( 6.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 6.000000:0.000000 ) )
         a_F=list(  ( 1.000000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:4.000000 ) ( 4.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:8.000000 ) ( 6.000000:8.000000 ) ( 6.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) )
         a_G=list(  ( 7.000000:4.000000 ) ( 4.000000:4.000000 ) ( 4.000000:3.000000 ) ( 6.000000:3.000000 ) ( 6.000000:2.500000 ) ( 4.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) ( 1.000000:6.500000 ) ( 2.500000:8.000000 ) ( 4.500000:8.000000 ) ( 6.000000:6.500000 ) ( 6.000000:6.000000 ) ( 7.000000:6.000000 ) ( 7.000000:7.000000 ) ( 5.000000:9.000000 ) ( 2.000000:9.000000 ) ( 0.000000:7.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 5.000000:0.000000 ) ( 7.000000:2.000000 ) )
         a_H=list(  ( 6.000000:9.000000 ) ( 5.000000:9.000000 ) ( 5.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:4.000000 ) ( 5.000000:4.000000 ) ( 5.000000:0.000000 ) ( 6.000000:0.000000 ) )
         a_I=list(  ( 0.000000:8.000000 ) ( 1.000000:8.000000 ) ( 1.000000:1.000000 ) ( 0.000000:1.000000 ) ( 0.000000:0.000000 ) ( 3.000000:0.000000 ) ( 3.000000:1.000000 ) ( 2.000000:1.000000 ) ( 2.000000:8.000000 ) ( 3.000000:8.000000 ) ( 3.000000:9.000000 ) ( 0.000000:9.000000 ) )
         a_J=list(  ( 7.000000:9.000000 ) ( 2.000000:9.000000 ) ( 2.000000:8.000000 ) ( 4.000000:8.000000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:3.000000 ) ( 0.000000:3.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) ( 5.000000:8.000000 ) ( 7.000000:8.000000 ) )
         a_K=list(  ( 1.000000:0.000000 ) ( 1.000000:4.000000 ) ( 2.500000:4.000000 ) ( 5.000000:1.500000 ) ( 5.000000:0.000000 ) ( 6.000000:0.000000 ) ( 6.000000:2.000000 ) ( 3.500000:4.500000 ) ( 6.000000:7.000000 ) ( 6.000000:9.000000 ) ( 5.000000:9.000000 ) ( 5.000000:7.500000 ) ( 2.500000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) )
         a_L=list(  ( 0.000000:0.000000 ) ( 6.000000:0.000000 ) ( 6.000000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) )
         a_M=list(  ( 1.000000:0.000000 ) ( 1.000000:8.000000 ) ( 1.500000:8.000000 ) ( 4.000000:5.500000 ) ( 6.500000:8.000000 ) ( 7.000000:8.000000 ) ( 7.000000:0.000000 ) ( 8.000000:0.000000 ) ( 8.000000:9.000000 ) ( 6.000000:9.000000 ) ( 4.000000:7.000000 ) ( 2.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) )
         a_N=list(  ( 1.000000:0.000000 ) ( 1.000000:6.750000 ) ( 7.000000:0.750000 ) ( 7.000000:0.000000 ) ( 8.000000:0.000000 ) ( 8.000000:9.000000 ) ( 7.000000:9.000000 ) ( 7.000000:2.250000 ) ( 1.000000:8.250000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) )
         a_P=list(  ( 6.000000:6.500000 ) ( 5.000000:6.500000 ) ( 5.000000:5.750000 ) ( 4.250000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:8.000000 ) ( 4.250000:8.000000 ) ( 5.000000:7.250000 ) ( 5.000000:6.500000 ) ( 6.000000:6.500000 ) ( 6.000000:7.500000 ) ( 4.500000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:4.000000 ) ( 4.500000:4.000000 ) ( 6.000000:5.500000 ) )
         a_Q=list(  ( 7.000000:2.000000 ) ( 6.500000:1.500000 ) ( 7.000000:1.000000 ) ( 7.000000:0.750000 ) ( 7.000000:0.000000 ) ( 6.500000:0.000000 ) ( 5.750000:0.750000 ) ( 5.000000:0.000000 ) ( 2.000000:0.000000 ) ( 0.000000:2.000000 ) ( 0.000000:7.000000 ) ( 2.000000:9.000000 ) ( 5.000000:9.000000 ) ( 7.000000:7.000000 ) ( 7.000000:4.500000 ) ( 6.000000:4.500000 ) ( 6.000000:6.500000 ) ( 4.500000:8.000000 ) ( 2.500000:8.000000 ) ( 1.000000:6.500000 ) ( 1.000000:2.500000 ) ( 2.500000:1.000000 ) ( 4.500000:1.000000 ) ( 5.000000:1.500000 ) ( 4.000000:2.500000 ) ( 4.000000:3.000000 ) ( 5.000000:3.000000 ) ( 5.750000:2.250000 ) ( 6.000000:2.500000 ) ( 6.000000:4.500000 ) ( 7.000000:4.500000 ) )
         a_R=list(  ( 6.000000:3.500000 ) ( 5.000000:4.500000 ) ( 6.000000:5.500000 ) ( 6.000000:7.500000 ) ( 4.500000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:8.000000 ) ( 4.250000:8.000000 ) ( 5.000000:7.250000 ) ( 5.000000:5.750000 ) ( 4.250000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:4.000000 ) ( 4.250000:4.000000 ) ( 5.000000:3.250000 ) ( 5.000000:0.000000 ) ( 6.000000:0.000000 ) )
         a_S=list(  ( 6.000000:8.000000 ) ( 5.000000:9.000000 ) ( 1.000000:9.000000 ) ( 0.000000:8.000000 ) ( 0.000000:5.000000 ) ( 1.000000:4.000000 ) ( 4.500000:4.000000 ) ( 5.000000:3.500000 ) ( 5.000000:1.500000 ) ( 4.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:2.250000 ) ( 0.000000:2.250000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 5.000000:0.000000 ) ( 6.000000:1.000000 ) ( 6.000000:4.000000 ) ( 5.000000:5.000000 ) ( 1.500000:5.000000 ) ( 1.000000:5.500000 ) ( 1.000000:7.500000 ) ( 1.500000:8.000000 ) ( 4.500000:8.000000 ) ( 5.000000:7.500000 ) ( 5.000000:6.750000 ) ( 6.000000:6.750000 ) )
         a_T=list(  ( 0.000000:8.000000 ) ( 3.000000:8.000000 ) ( 3.000000:0.000000 ) ( 4.000000:0.000000 ) ( 4.000000:8.000000 ) ( 7.000000:8.000000 ) ( 7.000000:9.000000 ) ( 0.000000:9.000000 ) )
         a_U=list(  ( 7.000000:9.000000 ) ( 6.000000:9.000000 ) ( 6.000000:2.500000 ) ( 4.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 5.000000:0.000000 ) ( 7.000000:2.000000 ) )
         a_O=list(  ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 5.000000:0.000000 ) ( 7.000000:2.000000 ) ( 7.000000:7.000000 ) ( 5.000000:9.000000 ) ( 2.000000:9.000000 ) ( 0.000000:7.000000 ) ( 0.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:6.500000 ) ( 2.500000:8.000000 ) ( 4.500000:8.000000 ) ( 6.000000:6.500000 ) ( 6.000000:2.500000 ) ( 4.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) )
         a_V=list(  ( 7.000000:9.000000 ) ( 6.000000:9.000000 ) ( 6.000000:3.500000 ) ( 3.500000:1.000000 ) ( 3.500000:1.000000 ) ( 1.000000:3.500000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:3.000000 ) ( 3.000000:0.000000 ) ( 4.000000:0.000000 ) ( 7.000000:3.000000 ) )
         a_W=list(  ( 1.000000:9.000000 ) ( 1.000000:1.000000 ) ( 1.500000:1.000000 ) ( 4.000000:3.500000 ) ( 6.500000:1.000000 ) ( 7.000000:1.000000 ) ( 7.000000:9.000000 ) ( 8.000000:9.000000 ) ( 8.000000:0.000000 ) ( 6.000000:0.000000 ) ( 4.000000:2.000000 ) ( 2.000000:0.000000 ) ( 0.000000:0.000000 ) ( 0.000000:9.000000 ) )
         a_X=list(  ( 7.000000:1.750000 ) ( 4.250000:4.500000 ) ( 7.000000:7.250000 ) ( 7.000000:9.000000 ) ( 6.000000:9.000000 ) ( 6.000000:7.750000 ) ( 3.500000:5.250000 ) ( 1.000000:7.750000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:7.250000 ) ( 2.750000:4.500000 ) ( 0.000000:1.750000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:1.250000 ) ( 3.500000:3.750000 ) ( 6.000000:1.250000 ) ( 6.000000:0.000000 ) ( 7.000000:0.000000 ) )
         a_Y=list(  ( 7.000000:9.000000 ) ( 6.000000:9.000000 ) ( 6.000000:7.750000 ) ( 3.500000:5.250000 ) ( 1.000000:7.750000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:7.250000 ) ( 3.000000:4.250000 ) ( 3.000000:0.000000 ) ( 4.000000:0.000000 ) ( 4.000000:4.250000 ) ( 7.000000:7.250000 ) )
         a_a=list(  ( 5.000000:0.000000 ) ( 5.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:1.750000 ) ( 3.250000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:3.500000 ) ( 1.500000:4.000000 ) ( 3.250000:4.000000 ) ( 4.000000:3.250000 ) ( 4.000000:2.500000 ) ( 5.000000:2.500000 ) ( 5.000000:5.000000 ) ( 4.000000:5.000000 ) ( 4.000000:4.500000 ) ( 3.500000:5.000000 ) ( 1.000000:5.000000 ) ( 0.000000:4.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 3.500000:0.000000 ) ( 4.000000:0.500000 ) ( 4.000000:0.500000 ) ( 4.000000:0.000000 ) )
         a_b=list(  ( 0.000000:0.000000 ) ( 0.000000:2.500000 ) ( 1.000000:2.500000 ) ( 1.000000:1.750000 ) ( 1.750000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 1.750000:4.000000 ) ( 1.000000:3.250000 ) ( 1.000000:2.500000 ) ( 0.000000:2.500000 ) ( 0.000000:9.000000 ) ( 1.000000:9.000000 ) ( 1.000000:4.500000 ) ( 1.500000:5.000000 ) ( 4.000000:5.000000 ) ( 5.000000:4.000000 ) ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.500000:0.000000 ) ( 1.000000:0.500000 ) ( 1.000000:0.500000 ) ( 1.000000:0.000000 ) )
         a_c=list(  ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.000000:0.000000 ) ( 0.000000:1.000000 ) ( 0.000000:4.000000 ) ( 1.000000:5.000000 ) ( 4.000000:5.000000 ) ( 5.000000:4.000000 ) ( 5.000000:3.000000 ) ( 4.000000:3.000000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 1.500000:4.000000 ) ( 1.000000:3.500000 ) ( 1.000000:1.500000 ) ( 1.500000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:2.000000 ) ( 5.000000:2.000000 ) )
         a_d=list(  ( 5.000000:0.000000 ) ( 5.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:1.750000 ) ( 3.250000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:3.500000 ) ( 1.500000:4.000000 ) ( 3.250000:4.000000 ) ( 4.000000:3.250000 ) ( 4.000000:2.500000 ) ( 5.000000:2.500000 ) ( 5.000000:9.000000 ) ( 4.000000:9.000000 ) ( 4.000000:4.500000 ) ( 3.500000:5.000000 ) ( 1.000000:5.000000 ) ( 0.000000:4.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 3.500000:0.000000 ) ( 4.000000:0.500000 ) ( 4.000000:0.500000 ) ( 4.000000:0.000000 ) )
         a_e=list(  ( 5.000000:1.500000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:3.500000 ) ( 1.500000:4.000000 ) ( 3.500000:4.000000 ) ( 4.000000:3.500000 ) ( 4.000000:3.000000 ) ( 1.000000:3.000000 ) ( 1.000000:2.000000 ) ( 5.000000:2.000000 ) ( 5.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.000000:5.000000 ) ( 0.000000:4.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_f=list(  ( 2.000000:0.000000 ) ( 2.000000:4.000000 ) ( 3.000000:4.000000 ) ( 3.000000:5.000000 ) ( 2.000000:5.000000 ) ( 2.000000:7.500000 ) ( 2.500000:8.000000 ) ( 3.500000:8.000000 ) ( 4.000000:7.500000 ) ( 4.000000:7.000000 ) ( 5.000000:7.000000 ) ( 5.000000:8.000000 ) ( 4.000000:9.000000 ) ( 2.000000:9.000000 ) ( 1.000000:8.000000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:4.000000 ) ( 1.000000:4.000000 ) ( 1.000000:0.000000 ) )
         a_g=list(  ( 5.000000:4.000000 ) ( 4.000000:4.000000 ) ( 4.000000:3.750000 ) ( 3.500000:3.250000 ) ( 1.500000:3.250000 ) ( 1.000000:3.750000 ) ( 1.000000:4.500000 ) ( 1.500000:5.000000 ) ( 3.500000:5.000000 ) ( 4.000000:4.500000 ) ( 4.000000:4.000000 ) ( 5.000000:4.000000 ) ( 5.000000:5.000000 ) ( 4.000000:6.000000 ) ( 1.000000:6.000000 ) ( 0.000000:5.000000 ) ( 0.000000:3.250000 ) ( 1.000000:2.250000 ) ( 4.000000:2.250000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:1.750000 ) ( 0.000000:1.750000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_h=list(  ( 5.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:3.500000 ) ( 1.500000:4.000000 ) ( 3.500000:4.000000 ) ( 4.000000:3.500000 ) ( 4.000000:0.000000 ) ( 5.000000:0.000000 ) )
         a_i=list(  ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) )
         a_j=list(  ( 5.000000:6.000000 ) ( 4.000000:6.000000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:2.000000 ) ( 0.000000:2.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_k=list(  ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:2.000000 ) ( 3.000000:0.000000 ) ( 4.000000:0.000000 ) ( 4.000000:0.500000 ) ( 2.000000:2.500000 ) ( 4.000000:4.500000 ) ( 4.000000:5.500000 ) ( 3.500000:5.500000 ) ( 1.000000:3.000000 ) ( 1.000000:9.000000 ) ( 0.000000:9.000000 ) )
         a_l=list(  ( 2.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:8.000000 ) ( 1.000000:8.000000 ) ( 1.000000:0.000000 ) ( 2.000000:0.000000 ) )
         a_m=list(  ( 6.000000:4.000000 ) ( 5.000000:5.000000 ) ( 3.500000:5.000000 ) ( 3.000000:4.500000 ) ( 2.500000:5.000000 ) ( 1.500000:5.000000 ) ( 1.000000:4.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:3.000000 ) ( 1.000000:3.250000 ) ( 1.750000:4.000000 ) ( 2.000000:4.000000 ) ( 2.500000:3.500000 ) ( 2.500000:0.000000 ) ( 3.500000:0.000000 ) ( 3.500000:3.500000 ) ( 4.000000:4.000000 ) ( 4.500000:4.000000 ) ( 5.000000:3.500000 ) ( 5.000000:3.000000 ) ( 5.000000:0.000000 ) ( 6.000000:0.000000 ) )
         a_n=list(  ( 5.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.500000:5.000000 ) ( 1.000000:4.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:3.250000 ) ( 1.750000:4.000000 ) ( 3.500000:4.000000 ) ( 4.000000:3.500000 ) ( 4.000000:0.000000 ) ( 5.000000:0.000000 ) )
         a_o=list(  ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.000000:0.000000 ) ( 0.000000:1.000000 ) ( 0.000000:4.000000 ) ( 1.000000:5.000000 ) ( 4.000000:5.000000 ) ( 5.000000:4.000000 ) ( 5.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 1.500000:4.000000 ) ( 1.000000:3.500000 ) ( 1.000000:1.500000 ) ( 1.500000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:2.500000 ) ( 5.000000:2.500000 ) )
         a_p=list(  ( 0.000000:7.000000 ) ( 0.000000:4.500000 ) ( 1.000000:4.500000 ) ( 1.000000:5.250000 ) ( 1.750000:6.000000 ) ( 3.500000:6.000000 ) ( 4.000000:5.500000 ) ( 4.000000:3.500000 ) ( 3.500000:3.000000 ) ( 1.750000:3.000000 ) ( 1.000000:3.750000 ) ( 1.000000:4.500000 ) ( 0.000000:4.500000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:2.500000 ) ( 1.500000:2.000000 ) ( 4.000000:2.000000 ) ( 5.000000:3.000000 ) ( 5.000000:6.000000 ) ( 4.000000:7.000000 ) ( 1.500000:7.000000 ) ( 1.000000:6.500000 ) ( 1.000000:6.500000 ) ( 1.000000:7.000000 ) )
         a_q=list(  ( 5.000000:7.000000 ) ( 5.000000:4.500000 ) ( 4.000000:4.500000 ) ( 4.000000:5.250000 ) ( 3.250000:6.000000 ) ( 1.500000:6.000000 ) ( 1.000000:5.500000 ) ( 1.000000:3.500000 ) ( 1.500000:3.000000 ) ( 3.250000:3.000000 ) ( 4.000000:3.750000 ) ( 4.000000:4.500000 ) ( 5.000000:4.500000 ) ( 5.000000:0.000000 ) ( 4.000000:0.000000 ) ( 4.000000:2.500000 ) ( 3.500000:2.000000 ) ( 1.000000:2.000000 ) ( 0.000000:3.000000 ) ( 0.000000:6.000000 ) ( 1.000000:7.000000 ) ( 3.500000:7.000000 ) ( 4.000000:6.500000 ) ( 4.000000:6.500000 ) ( 4.000000:7.000000 ) )
         a_r=list(  ( 4.000000:5.000000 ) ( 1.750000:5.000000 ) ( 1.000000:4.250000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:3.000000 ) ( 2.000000:4.000000 ) ( 4.000000:4.000000 ) )
         a_s=list(  ( 5.000000:2.000000 ) ( 4.000000:3.000000 ) ( 1.500000:3.000000 ) ( 1.250000:3.000000 ) ( 1.000000:3.250000 ) ( 1.000000:3.750000 ) ( 1.250000:4.000000 ) ( 1.500000:4.000000 ) ( 3.500000:4.000000 ) ( 3.750000:4.000000 ) ( 4.000000:3.750000 ) ( 4.000000:3.500000 ) ( 5.000000:3.500000 ) ( 5.000000:4.000000 ) ( 4.000000:5.000000 ) ( 1.000000:5.000000 ) ( 0.000000:4.000000 ) ( 0.000000:3.000000 ) ( 1.000000:2.000000 ) ( 3.500000:2.000000 ) ( 3.750000:2.000000 ) ( 4.000000:1.750000 ) ( 4.000000:1.250000 ) ( 3.750000:1.000000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.250000:1.000000 ) ( 1.000000:1.250000 ) ( 1.000000:1.500000 ) ( 0.000000:1.500000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_u=list(  ( 5.000000:5.000000 ) ( 4.000000:5.000000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_v=list(  ( 5.000000:5.000000 ) ( 4.000000:5.000000 ) ( 4.000000:2.500000 ) ( 2.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 3.000000:0.000000 ) ( 5.000000:2.000000 ) )
         a_w=list(  ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 2.500000:0.000000 ) ( 3.000000:0.500000 ) ( 3.500000:0.000000 ) ( 4.500000:0.000000 ) ( 5.000000:0.000000 ) ( 6.000000:1.000000 ) ( 6.000000:5.000000 ) ( 5.000000:5.000000 ) ( 5.000000:1.500000 ) ( 4.500000:1.000000 ) ( 4.000000:1.000000 ) ( 3.500000:1.500000 ) ( 3.500000:5.000000 ) ( 2.500000:5.000000 ) ( 2.500000:1.500000 ) ( 2.000000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:2.000000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) )
         a_x=list(  ( 0.000000:4.000000 ) ( 1.500000:2.500000 ) ( 0.000000:1.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:0.500000 ) ( 2.500000:2.000000 ) ( 4.000000:0.500000 ) ( 4.000000:0.000000 ) ( 5.000000:0.000000 ) ( 5.000000:1.000000 ) ( 3.500000:2.500000 ) ( 5.000000:4.000000 ) ( 5.000000:5.000000 ) ( 4.000000:5.000000 ) ( 4.000000:4.500000 ) ( 2.500000:3.000000 ) ( 1.000000:4.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) )
         a_y=list(  ( 5.000000:6.000000 ) ( 4.000000:6.000000 ) ( 4.000000:4.000000 ) ( 3.500000:3.500000 ) ( 1.500000:3.500000 ) ( 1.000000:4.000000 ) ( 1.000000:6.000000 ) ( 0.000000:6.000000 ) ( 0.000000:3.500000 ) ( 1.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:1.750000 ) ( 0.000000:1.750000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) )
         a_0=list(  ( 6.000000:5.250000 ) ( 5.000000:5.250000 ) ( 5.000000:3.250000 ) ( 1.375000:6.875000 ) ( 2.500000:8.000000 ) ( 3.500000:8.000000 ) ( 5.000000:6.500000 ) ( 5.000000:5.250000 ) ( 6.000000:5.250000 ) ( 6.000000:7.000000 ) ( 4.000000:9.000000 ) ( 2.000000:9.000000 ) ( 0.000000:7.000000 ) ( 0.000000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:5.750000 ) ( 4.625000:2.125000 ) ( 3.500000:1.000000 ) ( 2.500000:1.000000 ) ( 1.000000:2.500000 ) ( 1.000000:5.000000 ) ( 0.000000:5.000000 ) ( 0.000000:2.000000 ) ( 2.000000:0.000000 ) ( 4.000000:0.000000 ) ( 6.000000:2.000000 ) )
         a_1=list(  ( 1.000000:7.000000 ) ( 1.000000:1.000000 ) ( 0.000000:1.000000 ) ( 0.000000:0.000000 ) ( 3.000000:0.000000 ) ( 3.000000:1.000000 ) ( 2.000000:1.000000 ) ( 2.000000:9.000000 ) ( 1.000000:9.000000 ) ( 0.000000:8.000000 ) ( 0.000000:7.000000 ) )
         a_2=list(  ( 1.000000:6.000000 ) ( 1.000000:7.000000 ) ( 2.000000:8.000000 ) ( 3.000000:8.000000 ) ( 4.000000:7.000000 ) ( 4.000000:6.000000 ) ( 0.000000:2.000000 ) ( 0.000000:0.000000 ) ( 5.000000:0.000000 ) ( 5.000000:1.000000 ) ( 1.000000:1.000000 ) ( 1.000000:1.500000 ) ( 5.000000:5.500000 ) ( 5.000000:7.500000 ) ( 3.500000:9.000000 ) ( 1.500000:9.000000 ) ( 0.000000:7.500000 ) ( 0.000000:6.000000 ) )
         a_3=list(  ( 1.000000:6.500000 ) ( 1.000000:7.500000 ) ( 1.500000:8.000000 ) ( 3.500000:8.000000 ) ( 4.000000:7.500000 ) ( 4.000000:6.000000 ) ( 3.000000:5.000000 ) ( 2.000000:5.000000 ) ( 2.000000:4.000000 ) ( 3.000000:4.000000 ) ( 4.000000:3.000000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:2.500000 ) ( 0.000000:2.500000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) ( 5.000000:3.500000 ) ( 4.000000:4.500000 ) ( 5.000000:5.500000 ) ( 5.000000:8.000000 ) ( 4.000000:9.000000 ) ( 1.000000:9.000000 ) ( 0.000000:8.000000 ) ( 0.000000:6.500000 ) )
         a_4=list(  ( 1.000000:4.000000 ) ( 1.000000:5.000000 ) ( 3.500000:7.500000 ) ( 3.500000:5.000000 ) ( 1.000000:5.000000 ) ( 1.000000:4.000000 ) ( 3.500000:4.000000 ) ( 3.500000:0.000000 ) ( 4.500000:0.000000 ) ( 4.500000:4.000000 ) ( 5.500000:4.000000 ) ( 5.500000:5.000000 ) ( 4.500000:5.000000 ) ( 4.500000:9.000000 ) ( 3.500000:9.000000 ) ( 0.000000:5.500000 ) ( 0.000000:4.000000 ) )
         a_5=list(  ( 5.000000:8.000000 ) ( 1.000000:8.000000 ) ( 1.000000:5.000000 ) ( 4.000000:5.000000 ) ( 5.000000:4.000000 ) ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.000000:0.000000 ) ( 0.000000:1.000000 ) ( 0.000000:2.000000 ) ( 1.000000:2.000000 ) ( 1.000000:1.500000 ) ( 1.500000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 0.000000:4.000000 ) ( 0.000000:9.000000 ) ( 5.000000:9.000000 ) )
         a_6=list(  ( 4.000000:7.000000 ) ( 4.000000:7.500000 ) ( 3.500000:8.000000 ) ( 1.500000:8.000000 ) ( 1.000000:7.500000 ) ( 1.000000:5.000000 ) ( 4.000000:5.000000 ) ( 5.000000:4.000000 ) ( 5.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 1.500000:4.000000 ) ( 1.000000:3.500000 ) ( 1.000000:1.500000 ) ( 1.500000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:2.500000 ) ( 5.000000:2.500000 ) ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.000000:0.000000 ) ( 0.000000:1.000000 ) ( 0.000000:8.000000 ) ( 1.000000:9.000000 ) ( 4.000000:9.000000 ) ( 5.000000:8.000000 ) ( 5.000000:7.000000 ) )
         a_7=list(  ( 1.000000:7.000000 ) ( 1.000000:8.000000 ) ( 4.000000:8.000000 ) ( 4.000000:7.000000 ) ( 0.000000:3.000000 ) ( 0.000000:0.000000 ) ( 1.000000:0.000000 ) ( 1.000000:2.500000 ) ( 5.000000:6.500000 ) ( 5.000000:9.000000 ) ( 0.000000:9.000000 ) ( 0.000000:7.000000 ) )
         a_8=list(  ( 4.000000:6.500000 ) ( 4.000000:7.500000 ) ( 3.500000:8.000000 ) ( 1.500000:8.000000 ) ( 1.000000:7.500000 ) ( 1.000000:5.500000 ) ( 1.500000:5.000000 ) ( 3.500000:5.000000 ) ( 4.000000:5.500000 ) ( 4.000000:6.500000 ) ( 5.000000:6.500000 ) ( 5.000000:5.000000 ) ( 4.500000:4.500000 ) ( 5.000000:4.000000 ) ( 5.000000:2.500000 ) ( 4.000000:2.500000 ) ( 4.000000:3.500000 ) ( 3.500000:4.000000 ) ( 1.500000:4.000000 ) ( 1.000000:3.500000 ) ( 1.000000:1.500000 ) ( 1.500000:1.000000 ) ( 3.500000:1.000000 ) ( 4.000000:1.500000 ) ( 4.000000:2.500000 ) ( 5.000000:2.500000 ) ( 5.000000:1.000000 ) ( 4.000000:0.000000 ) ( 1.000000:0.000000 ) ( 0.000000:1.000000 ) ( 0.000000:4.000000 ) ( 0.500000:4.500000 ) ( 0.000000:5.000000 ) ( 0.000000:8.000000 ) ( 1.000000:9.000000 ) ( 4.000000:9.000000 ) ( 5.000000:8.000000 ) ( 5.000000:6.500000 ) )
         a_9=list(  ( 0.000000:8.000000 ) ( 0.000000:7.000000 ) ( 1.000000:7.000000 ) ( 1.000000:7.500000 ) ( 1.500000:8.000000 ) ( 3.500000:8.000000 ) ( 4.000000:7.500000 ) ( 4.000000:5.500000 ) ( 3.500000:5.000000 ) ( 1.500000:5.000000 ) ( 1.000000:5.500000 ) ( 1.000000:7.000000 ) ( 0.000000:7.000000 ) ( 0.000000:5.000000 ) ( 1.000000:4.000000 ) ( 4.000000:4.000000 ) ( 4.000000:1.500000 ) ( 3.500000:1.000000 ) ( 1.500000:1.000000 ) ( 1.000000:1.500000 ) ( 1.000000:2.000000 ) ( 0.000000:2.000000 ) ( 0.000000:1.000000 ) ( 1.000000:0.000000 ) ( 4.000000:0.000000 ) ( 5.000000:1.000000 ) ( 5.000000:8.000000 ) ( 4.000000:9.000000 ) ( 1.000000:9.000000 ) )
         a_Z=list(  ( 0.000000:1.750000 ) ( 6.000000:7.750000 ) ( 6.000000:8.000000 ) ( 1.000000:8.000000 ) ( 1.000000:7.000000 ) ( 0.000000:7.000000 ) ( 0.000000:9.000000 ) ( 7.000000:9.000000 ) ( 7.000000:7.250000 ) ( 1.000000:1.250000 ) ( 1.000000:1.000000 ) ( 6.000000:1.000000 ) ( 6.000000:2.000000 ) ( 7.000000:2.000000 ) ( 7.000000:0.000000 ) ( 0.000000:0.000000 ) )
         a_z=list(  ( 0.000000:5.000000 ) ( 4.000000:5.000000 ) ( 4.000000:4.000000 ) ( 4.000000:4.000000 ) ( 1.000000:1.000000 ) ( 4.000000:1.000000 ) ( 4.000000:0.000000 ) ( 0.000000:0.000000 ) ( 0.000000:1.250000 ) ( 2.750000:4.000000 ) ( 0.000000:4.000000 ) )
         a_t=list(  ( 4.000000:6.000000 ) ( 2.500000:6.000000 ) ( 2.500000:9.000000 ) ( 1.500000:9.000000 ) ( 1.500000:6.000000 ) ( 0.000000:6.000000 ) ( 0.000000:5.000000 ) ( 1.500000:5.000000 ) ( 1.500000:0.000000 ) ( 2.500000:0.000000 ) ( 2.500000:5.000000 ) ( 4.000000:5.000000 ) )
         a_?=list(  ( 1.000000:6.750000 ) ( 1.000000:7.500000 ) ( 1.500000:8.000000 ) ( 3.500000:8.000000 ) ( 4.000000:7.500000 ) ( 4.000000:5.250000 ) ( 2.000000:3.250000 ) ( 2.000000:0.000000 ) ( 3.000000:0.000000 ) ( 3.000000:3.000000 ) ( 5.000000:5.000000 ) ( 5.000000:8.000000 ) ( 4.000000:9.000000 ) ( 1.000000:9.000000 ) ( 0.000000:8.000000 ) ( 0.000000:6.750000 ) )
         procedure( PGtext()
         prog( ( str mag crd cnt char crds ocrds xcrd
             ycrd ocrds opoint obj objlist letterWidth )
             if( !boundp( 'activeLayList ) then
               activeLayList=list( "" )
             laylistmsg=""
             foreach( llay activeLayList
                sprintf( laylistmsg "%s %s", laylistmsg llay )
             hiEdgeMakeForm( "PGtext info..."
                list( 'str "Input text string" "string" "PART NUMBER" )
                list( 'mag "Input text magnification, ( a mag of 1.0 = text 9.0 microns tall )" "string" "1" )
                list( 'buildOn "Current active layer list for PGtext." "string" laylistmsg )
             foreach( ss geGetSelSet( hiGetCurrentWindow() )
                geDeselectObject( ss )
             mag=float( evalstring( mag ) )
             activeLayList=string2List( buildOn )
             oricrd=enterPoint(  ?prompts list( "Point to lower left corner of text" ) )
             objlist=nil
             foreach( multil activeLayList
                if( multil != nil then
                   crd=oricrd
                   cnt=0
                   while( cnt
                        cnt=cnt+1
                        char=substring( str cnt 1 )
                        if( char!=" " then
                            sprintf( char "%s%s" PGtextPreFix char )
                            if( !boundp( concat( char ) ) then
                                hiGetAttention()
                               println( "no symbol defined for character %s" char )
                                if(  ( atom objlist ) ( dbDeleteObject objlist ) ( mapcar '( lambda ( x ) ( dbDeleteObject x ) )  objlist )  )
                                return( nil )
                            crds=eval( concat( char ) )
                            ocrds=nil
                            foreach( point crds
                                xcrd=mag*car( point )
                                xcrd=float( round( xcrd/PGtextGrid ) )*PGtextGrid
                                ycrd=mag*cadr( point )
                                ycrd=float( round( ycrd/PGtextGrid ) )*PGtextGrid
                                opoint=list( ( xcrd+car( crd ) ) ( ycrd+cadr( crd ) ) )
                                ocrds=cons( opoint ocrds )
                            obj=dbCreatePolygon(  getEditRep() list( multil "drawing" ) ocrds  )
                           dbReplaceProp( obj "STREAM PROPERTY 1" "string"
                                    substring( char strlen( char ) strlen( char ) ) )
                            objlist=cons( obj objlist )
                            letterWidth=car( cadr( obj~>bBox ) )-car( car( obj~>bBox ) )
                        spacing=float( round( ( mag*PGtextSpacing )/PGtextGrid ) )*PGtextGrid
                        crd=list( ( car( crd )+letterWidth+spacing ) cadr( crd ) )
                   foreach( ss objlist
                      geSelectObject( ss )
         ; Procedure:    makeLetter
         procedure( makeLetter( @optional charName PGtextFile "tt" )
         prog( ( crds offset xo yo str )
             if( length( geGetSelSet(  hiGetCurrentWindow() ) )!=1 then
                  hiGetAttention()
                 println( "you must have exactly one item selected" )
                  return( nil )
             if( car( geGetSelSet(  hiGetCurrentWindow() ) )~>type!="geomInst" then
                  hiGetAttention()
                 println( "selected item must be a polygon" )
                  return( nil )
             else if( car( geGetSelSet(  hiGetCurrentWindow() ) )~>shape!="polygon" then
                  hiGetAttention()
                  return( nil )
             if( !charName then charName=textEntry( "input character" ) )
             if( !PGtextFile then PGtextFile=textEntry( "output file" ) )
             if( strlen( charName )!=1 then
                  hiGetAttention()
                 println( "must input exactly one character" )
                  return( nil )
             if( isFile( PGtextFile ) then
                  port=outfile( PGtextFile "a" )
             else
                  port=outfile( PGtextFile "w" )
             crds=car( geGetSelSet(  hiGetCurrentWindow() ) )~>path
             offset=car( car( geGetSelSet(  hiGetCurrentWindow() ) )~>bBox )
             xo=car( offset )
             yo=cadr( offset )
             sprintf( str "%s%s=list( " PGtextPreFix charName )
             foreach( crd crds
                  sprintf( str "%s ( %f:%f )" str ( car( crd ) - xo ) ( cadr( crd ) - yo ) )
             sprintf( str "%s )\n" str )
             fprintf( port "%s" str )
             close( port )
         This function takes a string of white-space separated words, and converts
         it to a list of strings which it then returns.
                  input:          theString -- string
                  return:         tmpList -- list of strings
         procedure(  string2List(  theString  )
             prog(  ( first last char tmpList done )
                 ;***** initialize the string and the character indexes into the string
                  tmpList = nil
                  first = 1
                  last = 1
                 if( theString == nil then ;***** check to see if nil string was provided
                      return( nil )
                 ;***** while there are characters in the string
                 while(  ( char = getchar( theString first ) ) != nil
                     ;***** if character is "whitespace" go for next one
                      if(  ( char == '\  ) || ( char == '\t ) || ( char == '\n ) then
                          first = first + 1
                     else ;***** otherwise look for the last character in the word
                          last = first + 1
                          done = nil
                         ;***** while there are characters and we've not encountered
                         ;       whitespace keep looking for the end of word
                          while(  ( ( char = getchar( theString last ) ) != nil  ) && !done
                                  done = t
                              else
                                  last = last + 1
                         ;***** now add the substring to the list
                          if(  tmpList == nil then
                              tmpList = tconc(  nil substring( theString first ( last - first ) ) )
                          else
                              tconc(  tmpList substring( theString first ( last - first ) ) )
                          first = last
                  return(  car( tmpList )  )
         /* End of Script  */
    Originally posted in cdnusers.org by CollinWeiss
