  3. Invoke a CIW environment variable in skill program
  • Views 18751
gs748
gs748 over 11 years ago
How can I invoke a CIW environment variable in skill program and assign the value of environment variable to a new variable.
I need value of environment variable assigned to a variable as I need pass new variable to a Perl program.
Thanks.
    I don't know what you mean by "CIW environment variable" (there's no such thing), but if you're talking about UNIX environment variables, you can get these and set these by doing:
    val=getShellEnvVar("MYVAR")
    setShellEnvVar("MYVAR=newvalue") ; the string includes an equal sign, with the value on the right
    so if you have it in a SKILL variable, you'd do something like this:
    newVal="hello"
    setShellEnvVar(sprintf(nil "MYVAR=%s" newVal))
    or
    setShellEnvVar(strcat("MYVAR=" newVal))
    If you're talking about cdsenv environment variables, you'd use the functions envGetVal() and envSetVal() for this. Look these up in the documentation if that's what you're asking about (I'm feeling lazy and don't want to work through a second example based on a wild guess of what you're actually asking...)
    Kind Regards,
