  3. Add and retrieve lists from a Master list
  • Views 17068
gs748
gs748 over 11 years ago
I have a scenario to save multiple lists into one Master list and retrieve each lists from Master list.
Example: I want following lists to be saved in 1 master list and be able to retrieve them using a for loop. Can you help on how to proceed with this task?
list1='("a" "b" "c")
list2='("d" "e" "f")
list3='("g" "h" "i")
    So do you mean:
    foreach(listN list(list1 list2 list3)
      printf("List to process: %L\n" listN)
    That seems fairly obvious, so I'm wondering if you meant something else by your question?
  • gs748
    Thanks for the reply; Your suggestion helps but I am still not getting me the desired output as below:
    • I am reading a csv file; each line of the csv file is read as a list as I need to use ‘?choices; option in hiCreateReportField function to display each line.
    • Lists can be of any number depending on the lines in the CSV file.
    I am able to you use your suggestion but ?choices option in hiCreateReportField function DOESN’T DISPLAY OUTPUT in below code. Can you please provide any suggestions.
    ……(code)…..
    lista = readcsv(ln); each line has 6 items separated by comma
    listN = cons(list a ListN) ; adding each list into listN
    ……(code)…..
    ;Create the report field.
      reportField = hiCreateReportField(
         ?name 'reportField
         ?selectMode 'single
         ?sort nil
         ?headers list(`….); has 6 headers to match 6 items in list
        ?choices list(listN) ; DOESN’T DISPLAY OUTPUT. Provides a blank screen with no errors
    ); end
    ……(code)…..
    The problem is that you've given a rather incomplete description of your problem, missing the most important parts - i.e. how the actual data is produced! Since you've not provided your readcsv function, I am assuming that it returns a list of strings.
    If you are then building listN as a list of these lists by consing on one at a time, listN will be a list of lists of strings.
    Then when you call hiCreateReportField, you are passing a list of list of lists of strings. That's not what it is expecting. The expectation is that it gets passed a list of lists, with each list being a list of strings. In other words, what you have as listN. So my wild guess with only being able to see a fraction of the code is that it should be ?choices listN rather than ?choices list(listN).
