  3. How to use db command (not ge command - geIsPathReentrant...
  • Views 1352
How to use db command (not ge command - geIsPathReentrant) to check a path whether has a self-intersecting ?
Charley Chen
Charley Chen over 11 years ago
Hi All,
I want to do a path check but not use geIsPathReentrant command , because when pcell has  geIsPathReentrant  ,
It will has error  when stream out .
Thank you,
Charley
    Hi Charley,
    There is no "db" equivalent of this function. You'd need to contact customer support so that we can file an enhancement change request for this.
    I've not seen any requests for this however - it's a fairly unusual thing to want to do within a pcell if you have control over the generation of the shapes in the first place - so why do you need this?
  • Charley Chen
    Hi Andrew ,
    Since the path has same point (duplicate point) if not well control the point .
    Thank you for help.
    Charley
    Charley,
    Detecting duplicate points in SKILL should be pretty easy - you can write your own function to do that, and then you can use that in your PCell.
