  3. comparison of two column and output as required
  • Views 14938
varun kumar D
varun kumar D over 11 years ago
I have given m value and corresponding l which is saved in file.  I want to compare the two column 1 to 1. for example if  l>=2.5 then it should print the corresponding column (m value) and save in the file and then add all the sum of total m.
m=1 l=l
m=2 l=2.5u
m=2 l=2.5u
m=2 l=2.5u
m=1 l=3.5u
m=2 l=2.5u
m=2 l=2.5u
m=2 l=2.5u
m=1 l=1u
m=1 l=1u
m=2 l=1.2u
m=14 l=5u
m=1 l=1.5u
m=2 l=1.2u
m=2 l=1.2u
m=1 l=1.2u
m=1 l=1.2u
m=14 l=5u
m=25 l=5u
m=25 l=5u
m=1 l=4u
m=1 l=4u
m=22 l=5u
m=1 l=1u
m=1 l=1u
m=2 l=1u
m=2 l=1.5u
m=1 l=1u
m=1 l=1.5u
m=3 l=1u
m=1 l=1u
m=1 l=1.5u
m=1 l=1u
m=1 l=1u
m=4 l=1u
m=4 l=1u
m=1 l=1.5u
m=1 l=1.5u
m=2 l=2u
m=1 l=2u
m=2 l=2u
m=2 l=1u
m=2 l=1u
m=1 l=2u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=3u
m=1 l=1u
m=8 l=1.4u
m=4 l=1u
m=1 l=0.8u
m=1 l=5u
m=2 l=1u
    Not a particularly precisely worded question, but it's probably something like this:
    prt=infile("varun.txt")
    outprt=outfile("varunOut.txt")
    sumM=0
    while(data=lineread(prt)
      m=caddr(car(data))
      l=caddr(cadr(data))
      when(numberp(l) && l>=2.5u
        fprintf(outprt "m=%d\n" m)
        sumM=sumM+m
    close(prt)
    close(outprt)
    printf("Sum of m is %d\n" sumM)
  • varun kumar D
    thts solved the problem ..thanks
