  3. Find a form
  • Views 15753
Find a form
psill000
psill000 over 11 years ago
What function can I use to find a form?
I have tried leGetTechFormList, but that seems to list cadence forms.
The form I am searching for is a custom form.
Paul
    Paul,
    Normally I'd bring up the form and do hiGetCurrentForm()->hiFormSym (I think that's the slot - but ->? will list it) to find the name of the form I'm dealing with. However, there's also hiFormList() which will list all forms defined. I used this in a reply yesterday: http://community.cadence.com/cadence_technology_forums/f/48/p/33188/1341362#1341362
    Note that some forms are dynamically generated, so this won't necessarily help you - depends on what you're looking for.
  • psill000
    Thanks for the info. The gui is a dynamic gui and I can find the gui, but variable does not have the menu variables.
    What I have
    foreach(gui hiFormList()
        if(rexMatchp("daForm" symbolToString(gui)) then
            guiList = cons(gui guiList))
     If I do a
    tmp = car(guiList)
    tmp~>??
    (_hiInValueSetCB nil)
    Am I saving the info correctly or do I need  to access variable with another function.
    Paul
    Paul,
    No need to do symbolToString, as rexMatchp can take a symbol as the second argument. In fact you could do this using:
    guiList=rexMatchList("daForm" hiFormList())
    Then you've got the symbol for the form, not the form data structure itself. So you'd need to do:
    tmp=symeval(car(guiList))
    Then you should be OK.
