  3. Flatten the list
  • Views 21060
Flatten the list
Sampatcharu
Sampatcharu over 11 years ago
Is there any default command to flatten the list?
Below is the requirement.
Input    = (1 2 3 (4 5) 6 (7 8) 9 19)
output  = (1 2 3 4 5 6 7 8 9 10)
Please help me on flattening the sub list.
Sampath
    Sampath,
    If it is only a single level you need to flatten, you can use:
    foreach(mapcan elem input
      if(listp(elem) elem list(elem))
    If it's multiple levels of list hierarchy, then it would be something like:
    procedure(CCFflattenList(lst)
      foreach(mapcan elem lst
        if(listp(elem) CCFflattenList(elem) list(elem))
    Note the above two weren't tested - I just typed them in as I have no access to SKILL today.
  • Sampatcharu
    Thank you very much Andrew for reply. Its working fine.
