  3. how to increase instance font size in graph
  • Views 16039
eashwar g
eashwar g over 11 years ago
hi,
if we change the font size in  graph properties ., it only increases marker points and the axis points size.So ,when we save the image we cant see the instance names clearly
is there any script for this
please suggest
i have attached the figure
    My guess is that you're talking about the size of the trace legend. Support for changing this was added in IC616 ISR3 - see Solution 20184836. You can also find details in cdsnhelp by searching for viva.traceLegend .
