  3. if statement ....
  • Views 19083
if statement ....
MarkGr15
MarkGr15 over 11 years ago
Below is my code, and output to a log file.  The problem is that the comma, in both if-else statement, never gets printed.  I added the printing of "First Corner" just to verify that the variable is 0.  If there is another way to skin this cat, I'm open to it, but I might have to share more of my intent for that.
thanks!
Mark
Code:
rdb=axlReadHistoryResDB(ocnxlGetCurrentHistory() ?session ocnxlGetSession())
printf("\n{")
printf("\n \"DATA_TYPE\": \"statistical\",") ;<-- OR functional OR worstcase $$$$$$mg
foreach(point rdb->points()
foreach(corner point->corners()
printf("\n\n %L: {" corner->name)
isFirstCorner=1
printf("\nFirst Corner %L\n" isFirstCorner)
;if(isFirstCorner printf("\nTest .....\n")
;isFirstCorner=0
;if(isFirstCorner printf("\nTest ....\n") printf("\nTest2 ....\n") )
foreach(test corner->tests()
if(isFirstCorner isFirstCorner=0 printf(",") )
printf("\n\n %L: {" test->name)
isFirstOutput=1
foreach(output test->outputs()
when(output->type=='expr
if(isFirstOutput isFirstOutput=0 printf(",") )
printf("\n \"%s\": %L" output->name output->value)
printf("\n }")
printf("\n }")
printf("\n }")
Output:  (part of it)
\o "mcmis_T:150": {
\o First Corner 1
\o
\o First Corner 0
\o
\o
\o "_mgraumlich:dg_1uA_mirror_1to8_Sim1:1": {
\o "Idisabled": 7.572342e-11
\o "Rout": 5.061094e+07
\o "IerrorMismatch": -4.725051e-10
\o }
\o }
\o
\o "mcproc_T:150": {
\o First Corner 1
\o
\o First Corner 0
\o
\o
\o "Idisabled": 7.292185e-11
\o "Rout": 5.46766e+07
\o "IerrorMismatch": 2.049591e-09
\o }
\o }
\o
\o "mcmis_T:150": {
\o First Corner 1
\o
\o First Corner 0
\o
\o
\o "Idisabled": 7.574724e-11
\o "Rout": 5.068103e+07
\o "IerrorMismatch": -1.195872e-10
\o }
\o }
\o
\o First Corner 1
    Mark,
    In SKILL, nil is false and anything else is true. So in this case your flag is being toggled between 0 and 1, both of which are considered true, and hence it only ever executes the then branch of the if(). Note that you're using the three-argument version of if() - if(condition thenexpr elseexpr) - I think this is intentional in your case, but if you want to be explicit you can do if(condition then thenexpr1 ... thenexprN else elseexpr1 ... elseexprM).
    So to cure your problem, change the assignments to be isFirstCorner=t or isFirstCorner=nil. That should do the trick. SKILL is not C, and so 0 does not mean false.
    Kind Regards,
