  3. defstruct issue
  • Views 16914
defstruct issue
balu soutani
balu soutani over 11 years ago
Hi ,
I use defstruct to define a variable
defstruct(var1 label msg)
If I Recall The Function Its Giving Warning
*WARNING* defstruct: Redefining Structure var1.
I will give u a simple example script:
Input File (test.txt):
M2 width=0.34um length=0.5um
M3 width=0.34um length=0.5um
script:
procedure(mytest(fileName)
      prog( ()
          inFile = infile(fileName)
          defstruct(struct width length) ; giving warning here
          setq(tabel (makeTable 'layers 0))
          while(gets(line inFile)
              lineInList = parseString(line " \n")
              tabel[nth(0 lineInList)] = make_struct(?width nth(1 parseString(nth(1 lineInList) "=")) ?length nth(1 parseString(nth(2 lineInList) "=")))
mytest("./test.txt")
    defstruct does not create a local variable - it is defining a global structure type - when you create an instance of it using make_XXX then that can be local.
    So there is no point putting the defstruct inside the procedure - if you do so, each time the function is called, it will redefine the structure and give a warning as you're seeing. So put it outside the procedure definition.
    I would also advise giving it a more meaningful and unique name than "struct". Given that it's in the global name space, anyone who uses defstruct(struct ...) will be clobbering the same structure name, and redefining make_struct() etc.
  • balu soutani
    Why defstruct giving error when i use like this
    defstruct(stringToSymbol("test_structure") a b c)
    First argument to the defstruct is symbol and i am also giving the same.
    Is there any other to do like this.
    Balu Soutani.
    This is because the first argument to defstruct is not evaluated. It's actually implemented as a macro - and this is because it's part of the language syntax and so you don't really want to have to quote the name of the structure to avoid it being evaluated (otherwise if it was a normal function, you'd have to do defstruct('structName 'field1 'field2 'field3) which would be clunky.
    So the first argument isn't evaluated (nor are the others) and so expecting it to be the result of stringToSymbol isn't going to work.
    I have no idea why you'd want to do that anyway - it seems a bit odd. Why not just do:
    defstruct(test_structure a b c)
