  3. Can we increase hilight marker width???
  • Views 15160
balu soutani
balu soutani over 11 years ago
Is there any function to create a hilighting marker with desired width
Balu Soutani
    If you're using the "hilight set" capabilities, then you could use geSetHilightSetHaloParameters() to use halo style highlights, and then you can specify the width etc. Otherwise you could alter the packet definition for the layer purpose used for the highlighting to make it draw with more than one pixel.
  • skillUser
    skillUser over 11 years ago
    Hi Bala,
    the only way I know of to 'thicken' up a marker line is to set halo parameters for it using geSetHilightSetHaloParameters() (the function sets halo parameters of the highlight set you've previously created) - there is a haloThickness parameter.  Try playing with this, I think it may be close to what you want?
    Lawrence.
