  3. Traversing a schematic hierarchically
  • Views 15960
vivekroy
vivekroy over 11 years ago
I am looking for a SKILL function which will take in input as the Library name, cellname and cell view; and if the cell view is of type schematic, will allow me to traverse it  hierarchically?
  • skillUser
    skillUser over 11 years ago
    Hi Vivek,
    Did you search for example code in this forum?
    I found this code posted by Marcel previously:
    ;; traverse schematic hier
    ;; and print all the instances that do not have any schematic view
    ;; most likely those are your primitives
    ;; cv - cv to scan
    ;; level - level down into hierarchy, used just to indent the printed lines.
    procedure( mpTraverseHierSch( cv @optional (level 0) )
        foreach(inst cv->instances
            if( cview =  dbGetAnyInstSwitchMaster(inst "schematic") then
                mpTraverseHierSch(cview level+1)
            else
                ;; some pretty  printing
                for( i 1 level
                    printf("    ")
                printf("%s %s/%s in %L\n"
                    inst->name inst->libName inst->cellName
                    list(cv->libName cv->cellName cv->viewName))
    mpTraverseHierSch(topCellView)
    Perhaps this is close to meeting your needs?  You would need to modify the function so that it accepted the library, cell and view name for the starting point, or add a simple wrapper, e.g. (not tested, I just typed this in...)
    procedure(vrTraverseSchHier(@key lib cell (view "schematic"))
      when(forall(arg list(lib cell view) !blankstrp(arg))
        mpTraverseHierSch(dbOpenCellViewByType(lib cell view nil "r"))
    You would call your function using the keyword arguments, e.g. vrTraverseSchHier(?lib "myLib" ?cell "myCell" ?view "schematic")
    Lawrence.
