  3. Create Nested Toggle (Check) Boxes
  • Views 18361
gs748
gs748 over 11 years ago
I am new to SKILL and would like to take your inputs on the below scenario.
I am creating a App form with Toggle (Check) Boxes for few lines in a file which are as below:
 <file lout >
Numbers
1,2,3,4,5
6,7,8,9,10
11,12,13,14,15
Characters
a,b,c,d,e
e,f,g,h,i
j,k,l,m,n
Letters
ab,cd,ef,gh,ij
kl,mn,op,qr,st
I read each line from file lout and create a Check Box for each line but if the user selects “Numbers” or “Characters” then all lines below “Numbers” or “Characters” must be checked until an empty line is read.
I have the below code which errors out with below message:
*Error* hiCreateToggleField: each toggle item must be a list of at least it's unquoted symbol representation
*Error* load: error while loading file - "te.il"
 Can you please help me with the error check on this code as I am not familiar with most SKILL functions . Thanks in advance.
CODE
procedure(readcsv(ln)
 cline=ln
 tline = substring(cline 1 strlen(cline)-1)
 pline=parseString(tline ",")
  i=length(pline)
;  printf("Length is %d\n" i)
   item8 = nth(i-1 pline)
   item7 = nth(i-2 pline)
   item6 = nth(i-3 pline)
   item5 = nth(i-4 pline)
   item4 = nth(i-5 pline)
;printf("ITEM'S 1-8:\n %L\n %L\n %L\n %L\n %L\n %L\n %L\n %L\n" item1 item2 item3 item4 item5 item6 item7 item8)
lista = list(item4 item5 item6 item7 item8)
printf("LIST ITEM'S:%L\n" lista)
lista
);end proc readcsv
port=infile("lout")
listN='()
listM='()
listNew='()
count =0
when(port
   while(gets(ln port)
        listb=readcsv(ln)
        listM = cons(listb listM)
        ;printf("ListM:%L\n" listM)
    );end while
   );end when
 close(port)
; Create Check Box
mytoggle = hiCreateToggleField(
 ?name ’toppings
 ?prompt "Toppings"
 ?choices listM
 ;?value ’( nil)
 ;?numSelect 1 )
hiCreateAppForm( ?name ’iceCreamForm
 ?formTitle "Ice Cream"
 ?callback "buildIceCreamCone()"
 ?fields list( mytoggle )
 ?help "cream" )
status = hiDisplayForm( iceCreamForm )
    This isn't going to work, because hiCreateToggleList doesn't do all of that for you. The structure you're passing to hiCreateToggleList is wrong (please read the manual, which makes it pretty clear that it's expecting a list of lists, where each list is a symbol and a string (the prompt), or just a symbol).
    Assuming you had just one section in a single list:
    Characters=' ("a" "b" "c" "d" "e"  "f" "g" "h" "i" "j" "k" "l" "m" "n" "o") ; I removed the duplicate "e" in  your example
    you could then do:
    choices=foreach(mapcar elem Characters list(stringToSymbol(elem) elem))
     ?name 'toppings
     ?prompt "Toppings"
     ?choices choices
     ?itemsPerRow 5
     ;?value ?( nil)
     ;?numSelect 1 )
    hiCreateAppForm( ?name 'iceCreamForm
     ?help "cream" )
    hiDisplayForm(iceCreamForm)
    Get that working first, and then figure out how to add a checkbox to turn the entire section on or off. Here's a slightly different example which shows the principle. This is using boolean buttons rather than toggle fields, but you hopefully can get the idea.
    Your code was too confusing and not particularly clear whether your rather abstract example would actually align with your real application, so I didn't spend the limited time I had writing something that would work for your example (only then to find that your real example is different in some fundamental way).
    /* abToggleForm.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 23, 1999
    Modified   Sep 16, 2009
    By         A.D.Beckett
    Functions for creating a variable list of toggles
    with all and none toggles. The list of toggles is
    in a scroll region.
    Attempted to make it resizable, but this rather contradicted
    with the scroll region, so left the scroll region in the form
    instead.
    Three main entry functions:
    abCreateToggleForm()
    abToggleFormGetSelected()
    abToggleFormSetSelected()
    Example:
    procedure(myToggleCB(form)
       printf("Selected Files were:\n")
       pprint(abToggleFormGetSelected(form))
       newline()
    hiDisplayForm(
      abCreateToggleForm(
         ?name 'myTogForm
         ?textList getDirFiles("/bin")
         ?prompt "Choose Files"
         ?callback 'myToggleCB
    SCCS Info: @(#) abToggleForm.il 09/16/09.12:22:46 1.5
    *                abCreateToggleForm(?name s_formName                *
    *              ?textList l_textitems ?prompt t_prompt               *
    *         [?formTitle t_formTitle] [?value b_defaultValue]          *
    * [?yStep x_yStep] [?formWidth x_formWidth] [?xPosition x_position] *
    *          [?toggleHeight x_height] [?toggleWidth x_width]          *
    *                      [?callback s_callback])                      *
    *     [?formType 'options/'nonoptions] [?buttonLayout 'OKCancel]    *
    *      Create a form full of toggle items, with an all or none      *
    *       button. Must provide at least the symbol for the form       *
    *              name, the list of items, and a prompt.               *
    procedure(abCreateToggleForm(@key
    	(name nil)
    	(formTitle "")
    	(textList nil)
    	(prompt "")
    	(value t)
    	(yStep 20) (formWidth 300)
    	(xPosition 220) (toggleHeight 200) (toggleWidth 250)
    	(callback nil)
    	(formType 'nonoptions)
    	buttonLayout
        let((toggleList togName (toggleNumber 0)
    	    (yPosition 0) topLabel allButton noneButton
    	    scrollRegion separator form)
    	; delete any existing form
    	when(boundp(name) && symeval(name)
    	    hiFormCancel(symeval(name))
    	    hiDeleteForm(symeval(name)))
    	; Default button layout
    	unless(buttonLayout
    	    buttonLayout=if(formType=='nonoptions 'OKCancel 'HideCancel)
    	; create the label at the top of the toggle list
    	topLabel=hiCreateLabel(?name 'label ?labelText prompt)
    	; create the toggles for each entry in the textList
    	toggleList=foreach(mapcar text textList
    	    ; create the name of the toggle
    	    togName=concat('toggle ++toggleNumber)
    	    ; return the first value in the group
    	    prog1(
    		; create the toggle and add it onto the list
    		list(
    		    hiCreateBooleanButton(
    			?name togName
    			?buttonText text
    			?callback
    			sprintf(nil "abToggleFormOtherButtonCB(%s '%s)"
    			name togName)
    			?value value
    			); hiCreateBooleanButton
    		    0:yPosition
    		    toggleWidth:yStep
    		    xPosition
    		    ); list
    		; increment the step
    		yPosition=yPosition+yStep
    		); prog1
    	    ); foreach mapcar
    	; add the line and the All and None toggles
    	separator=hiCreateSeparatorField(?name 'separator)
    	allButton=hiCreateBooleanButton(
    	    ?name 'All
    	    ?buttonText "All"
    	    ?callback sprintf(nil "abToggleFormAllButtonCB(%s)" name)
    	    ?value value
    	noneButton=hiCreateBooleanButton(
    	    ?name 'None
    	    ?buttonText "None"
    	    ?callback sprintf(nil "abToggleFormNoneButtonCB(%s)" name)
    	    ?value !value
    	; the sroll region itself
    	scrollRegion=hiCreateScrollRegion(
    	    ?name 'scrollRegion
    	    ?fields toggleList
    	    ?borderWidth 0
    	; create the form
    	form=hiCreateAppForm(
    	    ?name name
    	    ?fields list(
    		list(topLabel 0:0 formWidth:yStep*2)
    		list(scrollRegion 0:yStep*2 formWidth:toggleHeight)
    		list(separator 0:toggleHeight+yStep*2 formWidth:0)
    		list(allButton 0:toggleHeight+yStep*3 formWidth:yStep xPosition)
    		list(noneButton 0:toggleHeight+yStep*4 formWidth:yStep xPosition)
    	    ?formTitle formTitle
    	    ?formType formType
    	    ?buttonLayout buttonLayout
    	    ?callback callback
    	; store various information on the form
    	form->numButtons=toggleNumber
    	if(value then
    	    form->numSelected=toggleNumber
    	else
    	    form->numSelected=0
    	form
    *            abToggleFormOtherButtonCB(form field)             *
    *  Callback for each toggle (except all or none) on the form   *
    procedure(abToggleFormOtherButtonCB(form field)
        let((numSelected)
    	numSelected=form->numSelected
    	if(get(form->scrollRegion field)->value
    	    numSelected++
    	    numSelected--)
    	form->numSelected=numSelected
    	form->None->value=numSelected==0
    	form->All->value=numSelected==form->numButtons
    *              abToggleFormAllButtons(form value)              *
    *    Utility function to set all the buttons to a specified    *
    *                            value.                            *
    procedure(abToggleFormAllButtons(form value)
        let(((scrollRegion form->scrollRegion))
    	foreach(field scrollRegion->fieldList
    	    get(scrollRegion field)->value=value
    *                abToggleFormAllButtonCB(form)                 *
    *                 Callback for the All button                  *
    procedure(abToggleFormAllButtonCB(form)
        cond(
    	(form->All->value
    	    abToggleFormAllButtons(form t))
    	(form->numSelected==form->numButtons
    	    form->All->value=t)
    *                abToggleFormNoneButtonCB(form)                *
    *                 Callback for the None button                 *
    procedure(abToggleFormNoneButtonCB(form)
        cond(
    	(form->None->value
    	    abToggleFormAllButtons(form nil))
    	(form->numSelected==0
    	    form->None->value=t)
    *                abToggleFormGetSelected(form)                 *
    *  Function that may be used in the form callback function to  *
    *             retrieve all the selected item names             *
    procedure(abToggleFormGetSelected(form)
    	foreach(mapcar field
    	    setof(field scrollRegion->fieldList
    		get(scrollRegion field)->value)
    	    get(scrollRegion field)->prompt
    *          abToggleFormSetSelected(form promptValList)          *
    * Function that may be used to set (or unset) a list of fields. *
    *   The second argument is a list of lists, with each sublist   *
    *  being the prompt for the field, followed by t/nil to set or  *
    *                       unset the toggle.                       *
    procedure(abToggleFormSetSelected(form promptValList)
        let(((scrollRegion form->scrollRegion) (fieldTable makeTable('fields nil))
    	    foundField)
    	    fieldTable[get(scrollRegion field)->prompt]=field
    	foreach(promptVal promptValList
    	    foundField=fieldTable[car(promptVal)]
    	    if(foundField then
    		get(scrollRegion foundField)->value=cadr(promptVal)
    	    else
    		warn("No toggle with prompt %L on form\n" car(promptVal))
    	t
  • gs748
    Thank you for your response.  My scenario is a bit different here. I have a script which creates a tree structure. I want to add check box buttons to root of each  tree structure. Below is the script which creates a tree structure:  I would like to know if I can modify the below script to add check boxes to tree structure: Ex: I want to add checkboxes to Maths and Physics, and also for A Book, B Book, C Book and E Book. Whenever I check Maths checkbox it should check all the contents of Maths i.e. A Book and B Book.  Also, When I select Maths, I would like to unselect either A or B Book.:
    ; create a root tree
    maintree=hiCreateTree('index)
    ; create two tree items and append them to the root tree
    dow=hiCreateTreeItem('dow list("Maths"))
    nas=hiCreateTreeItem('nas list("Physics"))
    hiTreeAppendItem(maintree dow)
    hiTreeAppendItem(maintree nas)
    ; create two sub-trees
    dowTree=hiCreateTree('dows)
    nasTree=hiCreateTree('nass)
    ; put the two sub-trees into the two items created earlier
    hiItemInsertTree(dow dowTree)
    hiItemInsertTree(nas nasTree)
    ; add a few leaves for the dowTree and nasTree
    hiTreeAppendItem(dowTree hiCreateTreeItem('acom list("A Book" 80.5 1 "Good   Buy")))
    hiTreeAppendItem(dowTree hiCreateTreeItem('bcom list("B Book" 118 3 "Better")))
    hiTreeAppendItem(nasTree hiCreateTreeItem('ccom list("C Book" 27.750 4   "Better ")))
    hiTreeAppendItem(nasTree hiCreateTreeItem('dcom list("E Book" 28.925 5 "Best   Sell")))
    procedure( expandCB(name item)
        println("expanded")
        println(name)
        println(item))
    procedure( collapseCB(name item)
         println("collapsed")
         println(name)
         println(item))
    ; create tree table and use maintree as the value for ?choice
    treeField = hiCreateTreeTable(
           ?name 'treeField
           ?title "Books"
           ?titleAlignment 'center
           ?headers list(list("Name"  125    'left    'string)
                list("Price"    60       'left    'float3)
                list("Rating"       45      'center  'int)
                list("Recommendation"  125      'right)    )
                ?choice maintree
               ?callback "treeCB"
                ;?expandCallback "expandCB"
                ;?collapseCallback  "collapseCB"
    ; create a form
    form = hiCreateAppForm(
           ?name 'form
           ?formTitle "A Tree Book"
           ?fields list(  list(treeField 5:5 400:200 55) )
           ?initialSize 500:250)
    hiDisplayForm(form)
    You keep doing this - asking a question, and then following up an answer by stating that what you are doing is different - completely different to your original question. It rather makes me less inclined to answer your questions, because they're often somewhat vague, and then it turns out that you're doing something nothing like your question.
    The simple answer to your last question is that you cannot have checkboxes in a tree structure.
    Kind Regards,
