  3. Set BindKey to get Area of selected path or a polygon
  • Views 17956
Guruprasad S
Guruprasad S over 11 years ago
Hi ,
I am trying to write Skill code to get area of any selected metal of type Path or a Polygon ,
Please can anyone find solution for me , .
    I see you've appended the post that I was going to point you at: http://community.cadence.com/cadence_technology_forums/f/38/p/21797/1341614#1341614
  • Guruprasad S
    Thank you Andrew , ya i found your post for area :-)
  • Guruprasad S
    /*** Skill For Area of an Object With Popup Results ***/
    procedure(LAYareaSize()
    let(
    (object objType
    object = geGetSelectedSet()
    objT = car(object~>objType)
    println("s1")
    printf("objT is %s.\n" objT)
    if( objT == "polygon"
    then
    LAYpolyarea(object)
    else
    if( objT == "rect"
    then
    LAYrectarea(object)
    else
    printf("wrong shape.\n")
    hiDisplayAppDBox(
    ?name 'EMdbox
    ?dboxBanner "AREA"
    ?dialogType hicWarningDialog
    ?dialogStyle 'modeless
    ?buttonLayout 'Close
    ?dboxText sprintf(nil "Wrong shape Selected")
    );;;**if**
    );;;**polygon**
    );;;**procedure**
    procedure(LAYpolyarea(object)
    let(
    (object crdList sum firstPt lastPt dx sum
    object=geGetSelectedSet()
    crdList = object~>points
    printf("the crdList is %L." crdList)
    sum = 0
    firstPt = lastPt = caar(crdList)
    crdList = cdar(crdList)
    printf("the firstPt is %L \n." firstPt)
    printf("the crdList is %L.\n" crdList)
    (foreach crd crdList
    dx = difference((xCoord crd) (xCoord lastPt))
    sum = (plus sum (times dx (plus (yCoord crd)(yCoord lastPt))))
    lastPt = crd
    );;;**foreach**
    sum = (plus sum (times (difference (xCoord firstPt) (xCoord lastPt))(plus (yCoord firstPt)(yCoord lastPt))))
    area = (times 0.5 (abs sum))/1000000
    printf("Area in mmSq is %f.\n" area)
    i=area
    hiDisplayAppDBox(
    ?name 'EMdbox
    ?dboxBanner "AREA"
    ?dboxText sprintf(nil "Area of Polygon = %L mmSq" i)
    );;;*let*
    );;;*procedure(LAYpolyarea)**
    procedure(LAYrectarea(object)
    let(
    (object ll ur dx corners
    corners = object~>bBox
    ll = caar(corners)
    ur = car(cdar(corners))
    dx = (difference (xCoord ll) (xCoord ur))
    dy = (difference (yCoord ll) (yCoord ur))
    area = (abs (times dx dy))/1000000
    i=area
    hiDisplayAppDBox(
    ?name 'EMdbox
    ?dboxBanner "AREA"
    ?dboxText sprintf(nil "Area Of Rectangle = %L mmSq" i)
    );;;**procedure(LAYrectarea)**
    hiSetBindKey("Layout" "shift<key>a" "LAYareaSize()")
