  3. Detecting objects outside TOP LEVEL layout cell; Virtuoso...
  • Views 16555
Detecting objects outside TOP LEVEL layout cell; Virtuoso, prBoundary OBJECT
DannyRitt
DannyRitt over 11 years ago
I would like to detect all objects (Shapes) outside the TOP LEVEL layout block, prBoundary.
Support solution #20309046 works well for small cells. If the block is larger and includes large amount of objects (VIAs for example) it will take vast amount of time to run, (Hours) which makes it unusable.
There are few other solutions on Cadence support site and the community that simply do not do the job.
A robust solution is needed for efficient detection of objects outside TOP LEVEL block only, prBoundary object.
Cadence 6.1.x.
Many Thanks!
Danny
  • DannyRitt
    Cadence Support provided an efficient solution for the case. Below is the SKILL code for the community benefit.
    You can use the attached SKILL code in the layout window. It creates a menu item with the different submenus under it as shown in the below snapshot.
    1. Load the SKILL code in CIW:
    load "CCScheckOutsidePRB.il"
    2. Open Desired Layout in Layout-L or Layout-XL mode a new Menu 'DOB', gets added with the following choices as defined by the 'CCSUserPostInstallTriggerDOB'. Click on the Check Data Out of prBoundary option to create the markers in the layout design.
    2.1. "Check Data Out of prBoundary"
    2.2. "Find Marker by Zoom"
    2.3. "Explain Individual Marker"
    2.4. "Delete All Markers"
    3. Click on the "Find Marker by Zoom" and select the zoom to marker option to move to the specific marker.
    4. Menu item "Delete All Markers", deletes all the markers in the design.
    You may need to change the following two variables in the SKILL code as per your technology to define the purpose and layers to search for and avoid while checking;
    validPurpose = list("drawing" "pin")
    inValidLpp = list("text")
    * DISCLAIMER: The following code is provided for Cadence customers *
    * to use at their own risk. The code may require modification to *
    * satisfy the requirements of any user. The code and any modifications *
    * to the code may not be compatible with current or future versions of *
    * Cadence products. THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, *
    * INCLUDING WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED *
    * WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. *
    procedure(CCSTransformBBox(shape)
    let((flatList y)
    flatList = nil
    while(listp(shape)
    y = car(shape)
    flatList = append(flatList list(y))
    shape = cadr(shape) ; next shape
    );while
    if(flatList then
    geTransformUserBBox(shape~>bBox geGetInstTransform(flatList))
    else shape~>bBox)
    );let
    );procedure
    procedure(CCSTransformShapeBBox(cv box layer stopLevel)
    let(( finalList shapes att_list)
    shapes = dbGetOverlaps(cv box layer 0:stopLevel nil)
    finalList = nil
    foreach(shape shapes
    att_list = CCSTransformBBox(shape)
    if(att_list then
    finalList = append(finalList list(att_list))
    ) ;foreach
    finalList
    ) ;let
    ) ;procedure
    procedure(CCSmakeMessageMarker(shpType bBoxLLX bBoxLLY bBoxURX bBoxURY layerName layerPurpose cvId shapebBox)
    let(( message)
    ;println(shapebBox)
    warn("%s Shape with bBox %L on LPP = (%s %s) is Outside prBoundary Object bBox = ((%f %f) (%f %f)).\n\n" shpType shapebBox layerName layerPurpose bBoxLLX bBoxLLY bBoxURX bBoxURY)
    message = sprintf(nil "Database Out of prBoundary at LPP %s %s and bBox %L" layerName layerPurpose shapebBox)
    geCreateMarkerByBBox(cvId "warning" "Obj_Outside" message "" shapebBox)
    ); let
    ); procedure
    procedure(CCScheckDbOutPrBoundary(shpType bBoxLLX bBoxLLY bBoxURX bBoxURY shapebBox layerName layerPurpose cvId "tfffflttd")
    let((shpbBoxLL shpbBoxUR shpbBoxLLX shpbBoxLLY shpbBoxURX shpbBoxURY )
    ;println(shapebBox)
    shpbBoxLL = lowerLeft(shapebBox)
    shpbBoxUR = upperRight(shapebBox)
    shpbBoxLLX = xCoord(shpbBoxLL)
    shpbBoxLLY = yCoord(shpbBoxLL)
    shpbBoxURX = xCoord(shpbBoxUR)
    shpbBoxURY = yCoord(shpbBoxUR)
    printf("Checking Shape on LPP: (%L %L) with bBox %L...\n" layerName layerPurpose shapebBox)
    if(lessp(shpbBoxLLX bBoxLLX) == t then
    printf("\tshpbBoxLLX < bBoxLLX : %f < %f \n" shpbBoxLLX bBoxLLX)
    ); shpbBoxLLX < bBoxLLX
    if(lessp(shpbBoxLLY bBoxLLY) == t then
    printf("\tshpbBoxLLY < bBoxLLY : %f < %f \n" shpbBoxLLY bBoxLLY)
    ); shpbBoxLLY < bBoxLLY
    if(greaterp(shpbBoxURX bBoxURX) == t then
    printf("\tshpbBoxURX > bBoxURX : %f < %f \n" shpbBoxURX bBoxURX)
    ); shpbBoxURX > bBoxURX
    if(greaterp(shpbBoxURY bBoxURY) == t then
    printf("\tshpbBoxURY > bBoxURY : %f < %f \n" shpbBoxURY bBoxURY)
    ); shpbBoxURY > bBoxURY
    ); let
    ); procedure
    procedure(CCSDOB(@optional (cvId geGetWindowCellView()) "g")
    let(( boxWidth prBBox bBoxLL bBoxUR bBoxLLX bBoxLLY bBoxURX bBoxURY validPurpose inValidLpp allShapesTop allShapesBottom allShapesLeft allShapesRight )
    prBBox = cvId~>prBoundary~>bBox
    bBoxLL = lowerLeft(prBBox)
    bBoxUR = upperRight(prBBox)
    bBoxLLX = xCoord(bBoxLL)
    bBoxLLY = yCoord(bBoxLL)
    bBoxURX = xCoord(bBoxUR)
    bBoxURY = yCoord(bBoxUR)
    printf("********************************\n")
    printf("Checking all Hierarchical Shapes\n")
    ; Hierarchy Shapes
    foreach(layer cvId~>lpps
    if(member(layer~>purpose validPurpose) && !member(layer~>layerName inValidLpp)
    then
    ;;printf("LPP: (%L %L)...\n" layer~>layerName layer~>purpose)
    /* Checking within 5 micron of prBoundary, replace the value of boxWidth with new numbers if required*/
    boxWidth=5.0
    allShapesTop = CCSTransformShapeBBox(cvId list(bBoxLLX:bBoxURY bBoxURX:bBoxURY+boxWidth) list(layer~>layerName layer~>purpose) 32)
    allShapesBottom = CCSTransformShapeBBox(cvId list(bBoxLLX:bBoxLLY-boxWidth bBoxURX:bBoxLLY) list(layer~>layerName layer~>purpose) 32)
    allShapesLeft = CCSTransformShapeBBox(cvId list(bBoxLLX-boxWidth:bBoxLLY-boxWidth bBoxLLX:bBoxURY+boxWidth) list(layer~>layerName layer~>purpose) 32)
    allShapesRight = CCSTransformShapeBBox(cvId list(bBoxURX:bBoxLLY-boxWidth bBoxURX+boxWidth:bBoxURY+boxWidth) list(layer~>layerName layer~>purpose) 32)
    foreach(shpbBox allShapesTop
    CCScheckDbOutPrBoundary("Above PrBoundary" bBoxLLX bBoxLLY bBoxURX bBoxURY shpbBox layer~>layerName layer~>purpose cvId )
    ); foreach
    foreach(shpbBox allShapesBottom
    CCScheckDbOutPrBoundary("Below PrBoundary" bBoxLLX bBoxLLY bBoxURX bBoxURY shpbBox layer~>layerName layer~>purpose cvId )
    ); foreach
    foreach(shpbBox allShapesLeft
    CCScheckDbOutPrBoundary("Left of PrBoundary" bBoxLLX bBoxLLY bBoxURX bBoxURY shpbBox layer~>layerName layer~>purpose cvId )
    ); foreach
    foreach(shpbBox allShapesRight
    CCScheckDbOutPrBoundary("Right of PrBoundary" bBoxLLX bBoxLLY bBoxURX bBoxURY shpbBox layer~>layerName layer~>purpose cvId )
    ); foreach
    ); if
    ); foreach
    printf("\n\n");
    ); let
    ); procedure
    ;CCSDOB()
    procedure(CCSRemoveMarkers()
    if(geHasMarker(geGetWindowCellView()) == t then
    geDeleteAllMarker(geGetWindowCellView())
    ); if
    ); procedure
    procedure(CCSDOBMenu()
    let((no MenuItem CreateMenuItem)
    no = 0
    no = no + 1
    MenuItem = hiCreateMenuItem(
    ?name concat("Item" no)
    ?itemText "Delete All Markers"
    ?callback "CCSRemoveMarkers()"
    ); hiCreateMenuItem
    CreateMenuItem = cons(MenuItem CreateMenuItem )
    no = no + 1
    ?itemText "Explain Individual Marker"
    ?callback "geHiExplainMarker()"
    ); hiCreateMenuItem
    no = no + 1
    ?itemText "Find Marker by Zoom"
    ?callback "geHiCommonFindMarker()"
    ); hiCreateMenuItem
    no = no + 1
    ?itemText "Check Data Out of prBoundary"
    ?callback "CCSDOB()"
    ); hiCreateMenuItem
    hiCreatePulldownMenu(
    'CCSlayoutPulldownMenuDOB
    "DOB"
    CreateMenuItem
    ); hiCreatePulldownMenu
    ); let
    ); procedure
    procedure( CCSUserPostInstallTriggerDOB(args)
    hiInsertBannerMenu(
    args->window
    CCSDOBMenu()
    length( hiGetBannerMenus( args->window))
    ); hiInsertBannerMenu
    ) ; procedure
    deRegUserTriggers("maskLayout" nil nil 'CCSUserPostInstallTriggerDOB)
    deRegUserTriggers("maskLayoutXL" nil nil 'CCSUserPostInstallTriggerDOB)
