  3. Starting with skill
  • Replies 30
  • Subscribers 150
  • Views 27837
Starting with skill
Inas
Inas over 11 years ago
Now i have a simply skill code to generate a layout having a transistor, and i entered the parameters in a list.
one of the parameters i want o write is the SDshrink but i can't find out how to use it (write it).
ALso i confusde about the CDF parameter types and values, how can i know what should i write?
Thanks alot
  • Quek
    Quek over 11 years ago
    Hi Inas Mostafa
    I think you will need to check the PDK manuals for more info on sdShrink parameter because this question is specific to your PDK. I google a little and found the following info. Hope that it will be useful for you:
    http://newsgroups.derkeiler.com/Archive/Comp/comp.cad.cadence/2010-12/msg00023.html
    ;SDshrink ( 1 2 3 4 5 )
    ; 1 = finger #
    ; 2 = start top
    ; 3 = start bottom
    ; 4 = width
    ; 5 = contact spacing
    and the code if used in the pcell.
    instNTL=dbCreateParamInst(cv tranId
    "ntranl" 0:0 "R180" 1 list(
    list("w" "string" w_n_b )
    list("l" "string" l_n_b )
    list("fingers" "string" sprintf(nil "%d" f_n_b))
    list("m" "string" sprintf(nil "%d" m_n_b))
    stuff deleted.....
    list("SDshrink" "string" "(0 0 0 0 0)")
    Best regards
    Quek
  • Inas
    Thanks Quek for you fast reply.
    But i have another question please, is there a way to convert a layout done by hand to a skill code just to have an example to me.
    i found on google that in the layout GUI there is a Pcell menu from which we can compile to skill but i couldn't find that on cadence version i'm wrking on 6.1.6.
    Do you know is that available or not?
  • Quek
    Hi Inas Mostafa
    It is indeed possible to convert a drawn layout into a pcell using graphical pcells feature. This feature is still available in IC616. You can display the "Pcell" menu using "Launch->Plugins->Pcell".
    Please refer to $CDSHOME/doc/pcellref/pcellref.pdf for more details on creating a graphical pcell.
    Best regards
    Quek
  • Inas
    ok when i do compile he tells me that there is no parameter what does it mean?
  • Quek
    Hi Inas Mostafa
    Since you are creating a pcell, the tool expects at least 1 parameter. IC5141 package contains a tutorial on graphical pcell ($CDSHOME/doc/celltut/celltut.pdf). You can get a copy of this tutorial from COS.
    Best regards
    Quek
  • Inas
    sorry but can you tell me what does you mean by a parameter here?
  • Inas
    sorry for the wrong grammer " what do you mean with parameter?" :D
  • Quek
    Hi Inas Mostafa
    Parameter refers to the usual parameters (e.g. W, L, etc) that you can find on any regular pcell. You have to parameterize something in your layout (e.g. draw a rectangle and assign "w" as the width parameter).
    The cell tutorial in IC5141 package gives you step-by-step guide on creating a graphical pcell. It would be better for you to look through it.
    Best regards
    Quek
  • Inas
    I have another question away from skill please. Is there a way to connect to internal nets virtually without putting pins to them?
  • Quek
    Hi Inas Mostafa
    It would help other forum readers a lot if you can start a new thread for a new topic. This will allow the other readers to follow your issues more easily. It would also be good if you can provide more details in your questions. : )
    Please allow me to re-phrase your question and correct me if I am wrong:
    In layoutXL, it is possible to create virtual connections for top level  pin-to-pins or pin-to-shape by appending a colon to the pin/net name (E.g. ABC:) but it is not possible to create a virtual connection from a top level pin to a lower level pin/non-pin shape.
    Best regards
    Quek
