  3. Building the layout generation form...
  • Views 15992
saikanthatluri
saikanthatluri over 11 years ago
*WARNING* (DB-270002):  Pcell evaluation for gpdk180_v3.3/pmos/layout has the following error(s):
*WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: undefined function" gpdk180_evalMtlCvg))
*WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|PM0' because the instance master 'gpdk180_v3.3/pmos/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|PM0' because the instance master 'gpdk180_v3.3/pmos/layout' does not have a corresponding terminal 'G'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|PM1' because the instance master 'gpdk180_v3.3/pmos/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|PM1' because the instance master 'gpdk180_v3.3/pmos/layout' does not have a corresponding terminal 'G'.
*WARNING* (LX-2006): There were errors or warnings during layout generation.
help me out of this problem
    This function comes from a context file within the gpdk180 library. Your problem is because you have called the library "gpdk180_v3.3" rather than "gpdk180". The file "libInit.il" in the library gpdk180 expects the library to be called "gpdk180". If it isn't, you'll probably have seen (earlier in the log/CIW):
    Loading gpdk180/libInit.il ...
    Failed to load gpdk180/libInit.il successfully!
    Because of this, the context won't get loaded, and some of the utility functions needed by the pmos pcell (and many others) will not work.
    So please ensure that the library is called gpdk180. If you just add:
    INCLUDE $KITHOME/cds.lib.oa22
    (where $KITHOME is where the gpdk180 installation is) to your cds.lib, then it should all work.
  • saikanthatluri
    thanks for reply it is working fine
