  3. can not open the "search"
  • Replies 13
  • Subscribers 150
  • Views 12449
archive over 20 years ago
Hi guys
i have a problem that I can not open the "search" in my Cadence,  but other computers in my lab have no such problem,  is there any general reason and solution for this?
Thanks!
jren
Originally posted in cdnusers.org by jren
    Which "search" are you talking about? Which tool are you talking about (there is no tool called "Cadence")? The search could be the search in cdsdoc, in cdsFinder, in the layout editor, in the schematic editor - you need to be more explicit in your question, otherwise nobody will be able to give you an answer.
    Originally posted in cdnusers.org by adbeckett
    I am sorry if my question is not good, but I am trying to be more clear about that. Thanks for your patient.
    the search is in the cdsdoc.
    You still don't give any details of what is the problem. What exactly happens? Please give a step by step description of what happens.
    You've said the problem is with the search in cdsdoc, but not said what the symptoms are.
    ok, when I open the cdsdoc, there is a window, in the bottom of which there is a button called " search". then I open an Moxilla( I do not know if i can call internet exploer in Linux like this), after I press the button, it says, the "connection is refused".  So I can not open the search. I do not know if it is clear enough now.
    Regards
    jren
    Can you run "cdsdoc -test" and post the output here?
    is it this?
     CDSDoc 2.1 Installation verification
    Check system - Linux aqua.physics.sunysb.edu 2.4.21-4.ELsmp #1 SMP Fri Oct 3 17:52:56 EDT 2003 i686 i686 i386 GNU/Linux
    Checking installation directory... Done.
    Checking user environment variables... Done.
    Checking Netscape, make sure Netscape 4.51 (or higher) is in your PATH ...
              --- Warning: Netscape NOT found ---
    Checking Directory Structure...
    Directory Structure Check passed
    Done.
    archive over 19 years ago
    I have been attempting to make the Help button work as well. I have found some documentation that suggests that a symbolic link in your path to "mozilla" and called netscape will work. (I have done this with limited success!)
    Originally posted in cdnusers.org by vdvalk
    Try setting the "CDS_DEFAULT_BROWSER" environment variable. For example, I prefer to use firefox so I have:
    setenv CDS_DEFAULT_BROWSER firefox
    ...set in my .cshrc file. In the case of using mozilla instead of netscape, try this:
    setenv CDS_DEFAULT_BROWSER "mozilla"
    See "Choosing a default browser" in Chapter 6 of the CDSDoc User Guide: http://sourcelink.cadence.com/docs/files/Release_Info/Docs/cdsuser/cdsuser2.3/setPrefs.html#1033081
    Enjoy!
    Originally posted in cdnusers.org by aplumb
    I know its not the place to ask the question which is not related to Skill.
    But since the question had been asked, and that I have the same problem
    I tried your solution :
    in my .bashrc I put:
    CDS_DEFAULT_BROWSER=mozilla; export CDS_DEFAULT_BROWSER;
    Still the cdsdoc button "search" gives the following pop-up error :
    Error CDSDoc-002: Viewer can't start
    The web browser can't be started. On UNIX, make sure that your PATH environment variable includes the path to Netscape. On Windows/NT, make sure that either Internet Explorer 5.0 (or highrt) or Netscape 4.5.1 (or higher) is installed with standard registry entries.
    So if anyone has another idea since I cannot go to sourcelink.cadence.com ($login$ required) and cannot acces to Chapter 6 of the CDSDoc User Guide...
    Originally posted in cdnusers.org by ebecheto
    Are you using IC5141? If so, CDS_DEFAULT_BROWSER is not supported in the version of cdsdoc that comes with IC5141.
