  3. How to use the dbReplaceProp()?
  • Subscribers 150
  • Views 18797
archive over 20 years ago
Hi
e.g. I draw a inductance in schematic by instance from rsfq.basic
library, the property shows that:
Library Name: rsfq.basic
CellName : ind2
View Name: symbol
Instance Name: L1
PartName: ind2
Model Type: LR
Value Name: *
Value: 1.07
Model: L1*XL.
dbReplaceProp contains (g_object t_name t_propType g_value)
if I want to replace the value of inductance here by the inductance in
layout in the same cell,
is the g_object the ddGetObj("library" "cell" "schematic") , and what
is the t_name?
Thanks!
Originally posted in cdnusers.org by jren
    g_object would be the database Id of the instance. So for example, if it were selected, it would
    be car(geGetSelSet()) .
    t_name is the name of the property - hard to know what the property is actually called, because the chances are it is a CDF property. You can find the current properties on the instance by doing:
    car(geGetSelSet())~>prop~>name
    If you'd used ddGetObj("library" "cell" "schematic") as the value of the g_object argument, you'd have ended up setting a cellview meta-data property (the properties that show up when you do Edit Properties from the library manager, with the cellView selected (right mouse button over the view name).
    Originally posted in cdnusers.org by adbeckett
    Thanks!!
    I have a new question:
    Is there any way to get the schematic property dbId without openint the window?
    jren
    jren,
    Of course. You can access a cellView by using:
    cv=dbOpenCellViewByType("mylib" "mycell" "myView" "" "a")
    (the "a" stands for append mode - ifyou omit the last couple of arguments, it will open in read mode). See the documentation for more details.
    Then you can access all the instances using:
    cv~>instances
    Or you can find a named instance by name by using:
    inst=dbFindAnyInstByName(cv "I23")
    It sounds as if you could really benefit from attending a SKILL class. You can find details of these on the main Cadence web site - there is an "Education" link onthe front page.
    Thanks a lot! Actually, I started learning the SKILL and Cadence just a month ago, but now i have task from advisor about XL and the database thing, so there are many things I am confused with. Thanks again.
    jren
