  3. Mark Net to a path without net name in layout using skill...
  • Views 16369
Mark Net to a path without net name in layout using skill code for IC5141_USR6 .
marbs
marbs over 11 years ago
Hi All,
Does someone has a skill code to Mark Net a path that has no net name in the layout ?
Because if I use the Connectivity - Mark Net, then I select a net(path) to mark,
it does not work,  I am using IC5141_USR6.'
Thanks in advance.
Best Regards,
Marben
    Marben,
    Mark Net doesn't require connectivity in the layout, so there's no need for it to have a net name. It uses shape chasing to figure out the connectivity, starting from a point in the layout.
    There's no SKILL API equivalent (only leHiMarkNet()) in IC5141; leMarkNet (the non-human-interface API) was added in IC616, and takes an xy coordinate as the starting point.
    So if it's not working, there must be something wrong with the layers setup for the mark net command.
  • marbs
    Thank you very much for your reply.
    Best Regards,
    Marben
  • marbs
    Hi All,
    I found the solution to this problem .
    Here is what I did to make the Mark Net to work in IC5141 .
    Click Connectivity - Mark Net ,
    then click "F3"
    Select "Options" in Via Layers used by Mark Net .
    then click "Select Via Layers" .
    Fill the "layer1" "viaLayer" "layer2" textfield .
     for example : METAL1 VIA12 METAL2
                              METAL2 VIA23 METAL3
    Click "Add" button then "OK" button.
    Finally point at a net to mark in layout.
    The selected net will now be mark  .
    Best Regards,
    Marben
