  3. Annotate DC node voltages on terminals of user defined cellviews...
  • Subscribers 152
  • Views 19206
Annotate DC node voltages on terminals of user defined cellviews in Schematic
Atul Dwivedi
Atul Dwivedi over 11 years ago
Hi there,
In continuation with the problem mentioned here: http://community.cadence.com/cadence_technology_forums/f/48/t/33334 .
I have found that the problem is only in cells created by user (in Schematic:  Create->Cellview->From cellview). The DC node voltages are mentioned at the terminals of all the cells from analogLib and cells from the tech DK (nmos, pmos etc) (irrespective of the hierarchy), but not mine.
So, my question is simple, while creating cellview symbols from existing cellviews, what steps should I follows, so that wherever I instantiate this, the DC node voltages are annotated at the terminals?
(Also, if the cellviews are already created, what can be done now to show the DC node voltages at the terminals?).
Thanks and Regards,
Atul.
    Hi Atul,
    When using the schematic to symbol generator (using Create->CellView->From CellView), when the form appears with the list of pins on, there's a Load/Save checkbox. Turn that on, and then next to the Load button there's a cyclic field (which defaults to "digital"). Change this to "analog" and then hit load:
    This is assuming that the tsgTemplateMasters variable has been left at default. You can set the default template in your .cdsinit by using:
    envSetVal("schematic" "tsgTemplateType" 'string "analog")
    (note "artist" can be used instead of "analog" - they do the same thing).
    This means that generated symbols will have the cdsTerm labels on the pins.
  • Atul Dwivedi
    Thanks Andrew, for such a detailed explanation.
    I wont be able to test now, will get back with the results as soon as I am able to.
    Atul.
  • Atul Dwivedi
    Dear Andrew,
    I followed the steps you mentioned. But it did not work.
    I did not see an "analog" option in the cyclic list (no "digital" either), but I used "artist" instead.
    Any other thing I might be missing?
    Atul.
  • paulinho
    paulinho over 4 years ago in reply to Andrew Beckett
    Is it possible to edit the above mentioned symbol properties ´digital`/ `analog´ / `artist`  after the symbol has been created ?
    Andrew Beckett over 4 years ago in reply to paulinho
    No. It's not a property, so that wouldn't make sense. It defines the template which controls how the symbol is created, which labels are added and so on.
