  3. schSetWireColor(wireId color) in IC5141 ?
  • Views 1505
marbs
marbs over 11 years ago
Hi All,
What is the equivalent function of  "schSetWireColor(wireId  color)" in IC5141 ?
I want to change the selected wires color in the schematic.
I have the code below, it is working well in IC616 but not in IC5141 .
How can I make it to work in IC5141 ?
procedure(wc(color)
 wireId = css()
 counter = 0
 b = geGetSelSet()
 counter = 0
 cv = geGetSelSet()
 foreach(a cv= geGetSelSet()
    counter = counter +1
    layer = a~>layerNum
    printf("\nlayer = %d " layer)
    schSetWireColor(a color)
 ) ; foreach
Thanks in advance.
Best Regards,
Marben
    Marben,
    This function was new in IC616; prior to that there was no API for setting wire colors.
    I did write this solution a few years back:
    which explains how to delete the wire colors in schematic by removing the data structures used to store them, but it doesn't cover creating them in the first place. Some reverse engineering of the data structures could allow you to implement this in IC5141 potentially but I've not written anything to do that. If I have a moment, I'll put something together...
  • marbs
    Thank you very much for your reply.
    Best Regards,
    Marben
    Marben,
    During a SKILL training course, I wrote this - hopefully this will help:
    /* abSetWireColor.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 13, 2015
    Modified
    By
    Two functions which should work in releases prior to IC616
    to get and set the wire color on wires in the schematic.
    abSetWireColor(wireObject "red")
    abGetWireColor(wireObject) => "red"
    You also need to call hiRedraw() to redraw the window so that
    the changes can be seen.
    Note, this relies on the internal structure of how the wire
    color data is stored; however, the functions are written such
    that they will use schGetWireColor and schSetWireColor if they are
    available, so the code should be future-proof.
    The code only tries to set solid linestyles - so it assumes that
    you have solid linestyle defined in your display.drf. I did not
    try to make the code provide a schSetWireLineStyle equivalent
    in the interests of simplicity.
    SCCS Info: @(#) abSetWireColor.il 05/13/15.15:31:33 1.1
    *                   abGetWireColor(wire "d")                   *
    *             Return the color of a piece of wire              *
    procedure(abGetWireColor(wire "d")
        if(isCallable('schGetWireColor) then
            schGetWireColor(wire)
        else
            let((colorGroup parsed tf packet)
                ; Find a color group with the right name which is
                ; associated with the wire, and is also a member of
                ; the root group for color information
                colorGroup=car(exists(group wire~>groupMembers~>group
                    rexMatchp("^sch_" group~>name) &&
                    exists(mainGroup group~>groupMembers~>group
                        mainGroup~>name=="schDisplayPacketsGroup"
                if(colorGroup then
                    parsed=parseString(colorGroup~>name "_")
                    cadr(parsed)
                ; Default is to get the color from the wire drawing LPP packet
                else
                    tf=techGetTechFile(wire~>cellView)
                    packet=techGetLPPacketName(techGetLP(tf list("wire" "drawing")))
                    nth(5 drGetPacket("display" packet))
    *                abGetExistingColorGroup(wire)                 *
    *  Utility function to get the group associated with the wire  *
    *          which is related to the color information           *
    procedure(abGetExistingColorGroup(wire)
    *               abSetWireColor(wire color "dt")                *
    *                   Set the color on a wire.                   *
    procedure(abSetWireColor(wire color "dt")
        if(isCallable('schSetWireColor) then
            schSetWireColor(wire color)
        else
            if(drGetColor("display" color) then
                let((groupName currentGroup currentColor (add t) cv
                        mainGroup)
                    ; If the wire already has color information, either
                    ; delete the object from the current color group,
                    ; or leave it as is (add=nil)
                    currentGroup=abGetExistingColorGroup(wire)
                    when(currentGroup
                        currentColor=cadr(parseString(currentGroup~>name))
                        if(currentColor==color then
                            add=nil
                        else
                            dbDeleteObjectFromGroup(wire currentGroup)
                    when(add
                        cv=wire~>cellView
                        ; Either find the existing group for the color
                        ; requested, or create it
                        sprintf(groupName "sch_%s_solid_solid" color)
                        currentGroup=car(
                            exists(group cv~>groups group~>name==groupName))
                        unless(currentGroup
                            currentGroup=dbCreateGroup(cv groupName
                                list("deleteLast" "collection" "unordered"
                                    "uniqueName")
                        ; Add the wire to the color group
                        dbAddObjectToGroup(currentGroup wire)
                        ; Now see if the root group exists, and if not create
                        ; it
                        unless(exists(group currentGroup~>groupMembers~>group
                            group~>name=="schDisplayPacketsGroup")
                            mainGroup=car(
                                    group~>name=="schDisplayPacketsGroup"))
                            unless(mainGroup
                                mainGroup=dbCreateGroup(cv "schDisplayPacketsGroup"
                                        "uniqueName")
                            ; Add the color group to the root group
                            dbAddObjectToGroup(mainGroup currentGroup)
                        t
            else
                warn("Color %L for display \"display\" was not found" color)
