  3. Copy hierarchy with hierarchical rename
  • Views 20637
blankman
blankman over 11 years ago
I am looking to copy the hierarchy of a design, and rename each level of hierarchy to a new name, ie append with _v1, and then to have these new cells referenced in the new hierarchy. I’m wondering does this functionality exist already within virtuoso (IC6.1.6)? If not would this be possible to code in skill?
Brian.
  • skillUser
    skillUser over 11 years ago
    Hi Brian,
    Yes, take a look at Solution Article 11807102, I think it does what you are asking.
    Lawrence.
  • blankman
    Lawrence, great thanks! This copies and renames every cell below a specified cellview. Though what I'm looking for is to copy and rename only a certain number of hiearchical levels. Could this be implemented into this code? ie say adding a stopLevel argument.
    Brian.
  • skillUser
    Hi Brian,
    Not with that solution.  You could write something to traverse the hierarchy to a certain depth and perform the rename for each level (this could be very inefficient!) - I think you would need to do the rename using the ccp* functions...
    Bare bones structure, something like this:
    procedure( CCFtraverseHierSch( cv @optional (level 0) (maxDepth 32))
      when(level < maxDepth
        foreach(ih cv->instHeaders
          if( cview =  dbGetAnyInstSwitchMaster(car(ih~>instances) "schematic") then
            CCFtraverseHierSch(cview level+1 maxDepth)
          else
            ;; do the rename for this cell (instHeader) updating all instances of it
            ;; write this piece with ccpRename, based on the ccpCopy solution example
          ); if
        ); foreach
      ); when
    ); procedure CCFtraverseHierSch
    Hopefully this gives you an idea?
    Lawrence.
  • blankman
    Lawrence that's great thanks again. I should be able to string something together with this. Best, Brian.
  • blankman
    Lawrence,
    Thinking more on this, what I’m actually looking to do, rather than set a stop level, is to be able to input a hierarchical route to which to apply the cell rename to. Ie Xi1/Xi0/Xi5/Xi13/Xi8. Does that make sense? Could it be implemented? If so would you have any suggestions on how to do so?
    Brian.
