  3. Adding new item to already created custom menu (for all...
  • Views 17692
Adding new item to already created custom menu (for all Layout Editor windows)
Sheppy
Sheppy over 11 years ago
I am working on a library that contains many macro functions to automate certain parts of the layout. Depending on the need, per project some macro's will be needed/loaded, and some won't. All these macro's must be available in a pull-down menu, which will be available in all layout editor windows. All macro's will be loaded at start-up of Virtuoso, and I want to include in that code a part that adds a menu item for that particular macro.
One menu item is always loaded, so I used that to generate the menu. I have copied the code of: http://community.cadence.com/cadence_technology_forums/f/48/p/20591/1304715#1304715 to generate the menu and this single item.
For this topic, I'd like to refer to the aforementioned topic and the code as posted by Andrew. See below:
procedure(AmitAddMenu(args)
  let( (item1 item2)
    ;; create a couple of menu items
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "My First Item"
              ?callback "AmitFunctionOne()"
    item2 = hiCreateMenuItem( ?name 'item2 ?itemText "My Second Item"
              ?callback "AmitFunctionTwo()"
    ;; create a menu that includes the menu items and return a list of the
    ;; pulldown menus
    list(hiCreatePulldownMenu('AmitMenu "Amit Menu" list(item1 item2)))
  );let
); procedure
;; create a userMenuTrigger trigger that automatically adds the menu
deRegUserTriggers("maskLayout" nil 'AmitAddMenu)
So lets say, I load this code and get in all layout editor windows the menu with the two options.
How do I get a third item in this pull-down menu by code loaded at start-up of Virtuoso (this code will be loaded after the code with the two options of course)?
Thank you in advance.
With kind regards,
Sjoerd
  • Sheppy
    By the way, this is what I tried, and it kind of works:
    ;;; Procedure for the SSM Macro! This will always be there.
    procedure( sstSSMAddLayoutEditorMacroMenuItem( _args )
         let( ( item1 item2 )
            ;;; create a couple of menu items
                    ?name 'item1
                    ?callback "printf( \"%L\n\" geGetWindowCellView( hiGetCurrentWindow() ) )"
                    ?name 'item2
                    ?callback "printf( \"Option 2 clicked...\n\" )"
            ;;; create a menu that includes the menu items and returns a list of the pulldown menus
            list( hiCreatePulldownMenu( 'sstMacroMenu "SST Macro Menu" list( item1 item2 ) ) )
        ) ;;; end of let
    ) ;;; end of procedure sstSSMAddLayoutEditorMacroMenuItem
    deRegUserTriggers( "maskLayout" nil 'sstSSMAddLayoutEditorMacroMenuItem )
    ;;; Procedure for the STM Macro! This is for optional macro's.
    procedure( sstSTMAddLayoutEditorMacroMenuItem( _args )
         let( (    item
            item3
            ( newItemList nil ) )
            when( boundp( 'sstMacroMenu )
                ;;; Get the current items of the menu and put them in a list
                foreach( item sstMacroMenu~>_menuItemList
                    newItemList = tconc( newItemList get( sstMacroMenu item ) )
                ) ;;; end of foreach
                ;;; Add the new item to the back of the list.
                newItemList = tconc( newItemList hiCreateMenuItem(
                            ?name 'item3
                            ?itemText "My Third Item"
                            ?callback "printf( \"Option 3 clicked...\n\" )"
                newItemList = car( newItemList )
                list( hiCreatePulldownMenu( 'sstMacroMenu "SST Macro Menu" newItemList ) )
            ) ;;; end of when
        ) ;;; end of let
    ) ;;; end of procedure sstSTMAddLayoutEditorMacroMenuItem
    deRegUserTriggers( "maskLayout" nil 'sstSTMAddLayoutEditorMacroMenuItem )
    What is the problem with this approach?
    It generates a second pull-down menu. The first menu contains two items, and the second menu contains all three items. So the part of adding an item works, but the updating part of the existing menu does not work. How do I get this to work properly?
    Thanks in advance.
    With kind regards,
    Sjoerd
    Hi Sjoerd,
    There are several ways that this could be done, but I would probably do your second function as a userPostInstallTrigger rather than a userMenuTrigger (this is the fourth argument for deRegUserTriggers()). The code would not create and return a new pulldown menu, but instead modify the existing pulldown menu. So something like this (note this is just typed in and not tested at all):
    ;;; Procedure for the STM Macro! This is for optional macros.
         let( ( item3 )
            ; only add the new item if it is not there already
            when( boundp( 'sstMacroMenu ) && !sstMacroMenu->item3
                item3=hiCreateMenuItem(
                            ?name 'item3
                hiAddMenuItem(sstMacroMenu item3)
            ) ;;; end of when
        ) ;;; end of let
    deRegUserTriggers( "maskLayout" nil nil 'sstSTMAddLayoutEditorMacroMenuItem )
  • Sheppy
    Thank you for the quick response. And thank you for the perfect answer. It works like a charm. Bit embarrassing though that I did not find that procedure myself (the hiAddMenuItem one). And the code you wrote (without testing it yourself) worked straight out of the box.
    With kind regards,
    Sjoerd
    ps: I assigned a bind-key to the same call-back procedure and the menu item gets this bind-key printed next to it, automatically. Very neat!
