  3. loading sdb file in Corners Setup GUI ADEXL view using ...
  • Views 16806
loading sdb file in Corners Setup GUI ADEXL view using SKILL
gs748
gs748 over 11 years ago
How can I load sdb file in Corners setup GUI of ADEXL view using SKILL without opening up corners set up GUI and loading sdb file manually ?
Are there any SKILL APIs for it?
Thanks in advance!
    envSetVal( "adexl.gui" "defaultCorners" 'string "/path/to/corners.sdb" )
    This will cause the corners file to be loaded into ADE XL if no corners are defined. For more information, search in cdnshelp for "defaultCorners".
  • gs748
    Thank you for your response! If corners are defined in the sdb file what do we use instead of "defaultCorners" in the cmd => envSetVal( "adexl.gui" "defaultCorners" 'string "/path/to/corners.sdb" ) ?
    You'd use a different approach - it's not just a different env var name.
    With the ADE XL view open, you'd do:
    sess=axlGetWindowSession()
    sdb=axlGetMainSetupDB(sess)
    axlLoadCorners(sdb "/path/to/corners.sdb")
  • gs748
    Thank you! It worked.
