  3. lxGenFromSource related questions
  • Replies 7
  • Subscribers 150
  • Views 18472
Inas
Inas over 11 years ago
Please i want  generate a layout for schematic so o searched in the cadence layout manual and i found this command.
Then i got the schematic ID using dbOpenCellViewByType then i used the command like that
lxGenFromSource(schID "lib name (same as sch)" "layout cell name (same as sch)" "layout view name")
when i did that it gives me in the CIW error says (extra arguments or keyword missing)
Also in the rest of the fields i don't know what i have to write like the template file field also if i want to instantiate the instances there is a field in the command which is t_initCreateInstances but i don't know how to use it is that bu writing the names in the schematic or what?
Thanks a lot
BR,
Inas
    Hi Inas,
    Apart from the first argument (the schematic cellView ID), the other arguments are "keyword" arguments. It should be:
    lxGenFromSource(schID ?layLibName "lib name (same as sch)" ?layCellName "layout cell name (same as sch)" ?layViewName "layout view name")
    The examples in the documentation show this keyword argument convention.
  • Inas
    Aha i see i have to write ?layLibName and so on, i thought he just give me indication that i have to write that. But please may i ask why this is done here specifically in this function as i didn't see in other ones
    Many functions are defined this way - not just this one. Most of the "hi" functions use keyword arguments, and many others too. Quite a few of the "lx" functions are defined to take keyword arguments.
    SKILL supports two argument styles - pass by order, and pass by keyword. When a function is defined you can have a mixture of ordered parameters and keyword parameters. Usually keyword arguments are used for the case when you have a large number of arguments, many of which are optional - which is the case here.
  • Inas
    Aha i got it thanks for your explanation
  • Inas
    one more question please, for the fields CreatePin and instances and the other fields in the same command if i didn't write anything in them it will generate the default like the pins in OD layer with no labels so how can i make use of these fields? can i control the pin layers ans the instances position using these fields or how can i make use of them?
    Hi Inas,
    Look in the documentation for lxSetNetPinSpecs. Something like this:
    leSetEnv("createPinLabels" t) ; may need other cdsenv to control layers and heights for labels
    lxGenerateStart(schCv layCv)
    lxSetNetPinSpecs(?nets lxGetPinNets() ?lpp list("M1" "drawing") ?width 0.5 ?height 0.5)
    lxGenerateFinish(schCv layCv)
    this is a different API from using lxGenFromSource but achieves the same idea but with a bit more control.
  • San
    San over 11 years ago
    I am trying the steps as indicated. But I am not getting the instances/cells and pin placed in layout.
    Note: I am using Layout GXL as I don't have licence for XL !
    I am running following series of commands to generate layout from schematic using generate all from source. Everything comes up True as a result in CIW but when I open the resultant layout graphically , its blank. Please let me know what I am doing wrong,
    schematic_view = dbOpenCellViewByType("mylib" "mycell" "schematic")       ........Note: I already have schematic
    layout_view = dbOpenCellViewByType("mylib" "mycell" "layout" "maskLayout" "w")
    lxGenerateStart(schematic_view layout_view)
    lxSetNetPinSpecs(?nets lxGetPinNets() ?lpp list("M1" "Pin") ?width 0.5 ?height 0.5)
    lxGenerateFinish(schematic_view layout_view)
    I will appreciate your help on this.
    San
