  3. Copy a particular line of text file to a new file using...
  • Replies 8
  • Subscribers 150
  • Views 20263
Copy a particular line of text file to a new file using SKILL
jarilak
jarilak over 11 years ago
Hi....
I have one text file.From that file, i need to copy some set of lines to a new file.For this copying, i need to read each & every line of the text file and compare them with some reference lines.Is there any keywords or SKILL function available in SKILL.? Can anyone help me......?
Thanks & regards
Jarilak.r
    I have no idea what you're asking here (this part or the rest of your question). Please clarify your question, otherwise it's unlikely anyone will be able to answer it without a lucky guess as to what you're really after.
  • jarilak
    Hi...
     I am looking for little help to write a skill code for copying particular lines from a text file to a new text file. Since my original text file may contains more than 2000 lines.From that file i need  to filter some lines & copying them to new file.
    thanks & regards
    Jarilak.r
    Jarilak.r,
    That's still a pretty vague question, so here's a wild guess answer which may or may not be relevant.
    ; compile a (perl-compatible) regular expression to match lines. In
    ; this case if either of the words "wild" or "guess" appear on the input line
    pattern=pcreCompile("wild|guess")
    inp=infile("./input.txt")
    outp=outfile("./output.txt")
    when(inp && outp
      while(gets(line inp)
        when(pcreExecute(pattern line)
          fprintf(outp "%s" line)
      close(inp)
      close(outp)
  • jarilak
    Hi Andrew....
    This is my question.Here i have the part of text file that has more than 2000 lines.
    RULECHECK mt30m4_xx_mt30m4_un_mincoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m4_xx_mt30m4_un_maxcoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m3_xx_mt30m3_un_mincoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m3_xx_mt30m3_un_maxcoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m2_xx_mt30m2_un_mincoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m2_xx_mt30m2_un_maxcoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m1_xx_mt30m1_un_mincoverage ................... TOTAL Result Count = 0
    RULECHECK mt30m1_xx_mt30m1_un_maxcoverage ................... TOTAL Result Count = 0
    RULECHECK mt08m2_xx_mt08m2_un_mincoverage ................... TOTAL Result Count = 41
    RULECHECK mt08m2_xx_mt08m2_un_maxcoverage ................... TOTAL Result Count = 0
    RULECHECK mt08m1_xx_mt08m1_un_mincoverage ................... TOTAL Result Count = 31
    RULECHECK m1_to_m1 .......................................... TOTAL Result Count = 1
    RULECHECK m1_no ............................................. TOTAL Result Count = 0
    RULECHECK m2_to_m2........................................... TOTAL Result Count = 5
    RULECHECK m1_ma ............................................. TOTAL Result Count = 0
    RULECHECK m1inv_ma .......................................... TOTAL Result Count = 0
    From the above file, i need to filter & copy particular lines as below as.
    Looking for help...
    Thanks & regards
    Jarilak.r
    Couldn't you just adapt my example then? Something like:
    pattern=pcreCompile("mt08m2_xx_mt08m2_un_mincoverage|mt08m1_xx_mt08m1_un_mincoverage|m1_to_m1|m2_to_m2")
    Or you could use something like:
    listOfRules=list("mt08m2_xx_mt08m2_un_mincoverage" "mt08m1_xx_mt08m1_un_mincoverage" "m1_to_m1" "m2_to_m2")
    when(inp && outp
        when(member(cadr(parseString(line)) listOfRules)
      close(inp)
      close(outp)
    This approach would assume that the second word on each input line has whitespace either side of it (so in your example text it omits m2_to_m2 because that has a "." immediately after m2_to_m2).
  • Sheppy
    Sheppy over 11 years ago
    Hi Jarilak.r and Andrew,
    Jarilak, what I understood from your response to Andrew, is that you're only interested in copying lines from the DRC run results file which report errors. So rules that have a results count greater than 0. For that you just have to change the suggested code of Andrew.
    This particular part should be altered:
    listOfRules=list("TOTAL Result Count =" "TOTAL Result Count = 0")
    The "when" should check that the first string of listOfRules list IS part of the line, and then it should make sure that the second string of listOfRules IS NOT part of that same line, thus enduring that only lines with total result count greater than 0 are copied.
    How to exactly do this, I would have to look into. It doesn't work with the "member(...)" solution, since this particular example of code works only for strings without spaces (parseString = Breaks a string into a list of substrings with break characters). You would have to use regular expression matching.
    With kind regards,
    Sjoerd
    Sjoerd, thanks for your suggestion. I'd not noticed that all the lines that Jarilak had wanted were those with a result count of other than 0. Of course, we're still guessing what Jarilak actually wants to do!
    Jarilak, this goes to show the importance of clearly stating what you want. In fact the first step of writing any program is to identify what it should do - i.e. defining the algorithm. The actual step of converting that algorithm into a specific language is secondary. If you can't state the algorithm clearly in English (or in a pseudo-langauge) first, there's little hope of implementing it in SKILL.
    If indeed you wanted all the lines with Total Result Count != 0 then I would do something like:
    pattern=pcreCompile("TOTAL Result Count =")
    when(inp && outp
        when(pcreExecute(pattern line) && atoi(car(last(parseString(line))))!=0  ; check line matches and has the last token being non-zero
      close(inp)
      close(outp)
    Please be more precise in your questions next time - whilst I understand that people are new to a programming language, that doesn't mean that it's OK to ask poorly framed questions where it requires guesswork to work out what you want. It's easier in those circumstances to just ignore the question and focus on something where a more precise question has been asked, given that we're all volunteers and have limited spare time.
    Kindest regards,
  • jarilak
    Hi Sjoerd & Andrew
    thanks for ur reply & am new to SKILL world.Now only, I started to learn SKILL & will come with question in precise.
    thanks & regards
    Jarilak.r
