  3. RHEL6 Bindkey problem in schematic editor
  • Views 14837
LayEngFME
LayEngFME over 11 years ago
We have just began with updating the machines to RHEL6 and covered a problem with a bindkey in the schematic editor!
As standard, Shift + 9 is set as the default bindkey for removing the probes in the schematic, but this bindkey is not working anymore with cadence 616 and RHEL6! If i change it eg to SHIFT + 8, it is working again!
Can anybody help me or knows this problem?
Thanks in advance, BR
Franz
    Franz,
    I was surprised this was anything to do with RHEL6, but then again I'm using RHEL6 anyway. I thought this was more to do with the IC61X release as a consequence of Qt being used. See solution 11682614. On my UK keyboard, shift-9 is "(", and so I can use <Key>( instead.
    If you use the bindkey editor (Options->Bindkeys), you can go into the bindkey field itself and press the key combination and it will generate the appropriate incantation for that key.
  • LayEngFME
    At first the positive, it is working again! :) Thanks!
    We tried it with several 61x versions and RHEL5 -> No problem, everything is working fine!
    And now, just to be sure, i have also tried 615 and RHEL6 and then I had the same problem!
    I don't know what causes this problem, but this workaround works and so the rest doesn't matter!
    Thank you Andrew!
    BR
    Franz
