  3. Send customized output to ADE outputs list
  • Views 14167
ChrisEAS
ChrisEAS over 11 years ago
Hi.
I would like to customize the selection of outputs in ADE (e.g. available via Outputs -> To Be Plotted -> Select On Schematic). By default you can click a net or a terminal which immediately sends back a voltage or current probe to ADE.
My goal is to extent this behaviour by sending back a customized expression to ADE outputs when clicking on an instance with "Ctrl+Left Mouse".
I already tried to create a key binding like so
hiSetBindKey("Schematics" "Ctrl<Btn1Down>" "myCallback()" )
However, the callback should be restricted to the "Select On Schematic" mode. Could you please give me an idea how to achieve this?
Chris
