  3. Renaming a net connected to an instance terminal in a s...
  • Subscribers 148
  • Views 15778
Renaming a net connected to an instance terminal in a schematic
rajkhiremath
rajkhiremath over 11 years ago
Hi andrew,
I have a following requirement. can you please let me know how is this possible.
I have instantiated nand symbol and it has pins in0 in1 out vdd vss vnw vsb. There is a terminal by name VDD. I added wire to vdd and vnw and labelled them as VDD. Now i only want to rename the net connected to vnw ( which is VDD ) as VNW through skill code.
Thank you ...
Raj
    Raj,
    I split this post from the old thread you'd added it to (the Forum Guidelines ask you not to post on old threads to avoid confusion).
    All you need to do is change the value of the wire label and then run the schematic checker again. If you can find that label, simply do:
    labelId~>theLabel="VNW"
    schCheck(cvId)
    and that should do it. Not clear precisely where you're starting from, so I'm just giving  you a broad point in the right direction. You don't really need to do all the connectivity creation yourself because the schematic checker can do that for you (and you need to make sure everything is OK and following schematic conventions otherwise a subsequent check-and-save may break things).
