  3. Compare list content no matter on order
  • Views 18966
berndfi
berndfi over 11 years ago
Hi
I want to compare the content of 2 lists not depended on the
list order and nondestructive on the original lists.
e.g.
listA = list(“a” “b” “c”)
listB = list(“a” “c” “b”)
listC = list(“a” b”)
listD = list(“a” “b” “c” “d”)
listA == listB => t
listA == listC => nil
listA == listD =>nil
I found a very pragmatic approach, but I’m wondering if there
isn’t any better way of implementing such a common task?
Best regards,
 Bernd
 1 procedure(compareListContent(listA listB "ll")
 2     let((returnVal)
 3
 4     if(length(listA) == length(listB) then
 5         foreach(element listA
 6             if(member(element listB) then
 7                 returnVal = t
 8             else
 9                 returnVal = nil
10             ) ;; close if
11         ) ;; close foreach
12     else
13         returnVal = nil
14     ) ;; close if
15
16     ) ;; close let
17 ) ;; close proecedure
    Hi Bernd,
    It depends to some extent as to whether you have repeated entries in lists. Actually your code won't work anyway (assuming you fix the missing returnVal on line 15 because it will only actually tell you whether the last entry). but even if you used a forall instead of a foreach, it would not work if there was repetition in the first list but not in the second. In other words, if the code was:
    forall(element listA
    then it works if you have your listA/listB examples above, but if you have:
    listA=list("a" "b" "b")
    listB=list("a" "c" "b")
    It would still return t. I guess you could use:
    length(listA)==length(listB) && forall(element listA member(element listB)) && forall(element listB member(element listA))
    Even that's not really correct though because you could have:
    listB=list("b" "a" "a")
    and the expression above would return t.
    Also, the code wouldn't be terribly efficient for long lists. A couple of simple possibilities:
    sort(copy(listA) 'alphalessp)==sort(copy(listB) 'alphalessp)
    This stops it being destructive by using copy. Another (maybe less costly) implementation would be:
    procedure(CCFcompareListContent(listA listB)
      let(((contentCount makeTable('counts 0)))
        foreach(elem listA contentCount[elem]=contentCount[elem]+1)
        foreach(elem listB contentCount[elem]=contentCount[elem]-1)
        forall(elem contentCount zerop(contentCount[elem]))
    I didn't bother checking if the lists where the same length first, because that adds two more list iterations to the code - a bit of profiling might show that to be beneficial for long lists.
    I'm sure there are other ideas, but I'd thought I'd throw these out there.
  • berndfi
    Thanks Adrew, actually this is what I was looking for sort(copy(listA) 'alphalessp)==sort(copy(listB) 'alphalessp). Bernd
    Bernd,
    No problem. My usual over-engineered answer at least gave you a choice of solutions ;-)
