  3. Skill form to browse text file, select and view
  • Views 19366
Sandeep4386
Sandeep4386 over 11 years ago
Hi All,
Could anyone guide me how I can write a callback function for  a view button on a skill form? When I click this view button, I would like to browse and select multiple text files from UNIX directory structure and  then view them  using Virtuoso text viewer.
I am using IC616
Sandeep
  • skillUser
    skillUser over 11 years ago
    Hi Sandeep,
    The key to this could be the ddsFileBrowseCB() function, but here's a fully working example:
    procedure(CCFviewFile()
      let( (fileName selectFile viewFile form)
        fileName = hiCreateStringField(
          ?name             'fileName
          ?prompt           "File to View"
        selectFile = hiCreateButton(
          ?name             'selectFile
          ?buttonText       "Select File"
          ?callback         "ddsFileBrowseCB(hiGetCurrentForm() 'fileName)"
        viewFile = hiCreateButton(
          ?name             'viewFile
          ?buttonText       "View File"
          ?callback         "view(hiGetCurrentForm()->fileName->value)"
        form = hiCreateAppForm(
          ?name             'CCFviewFileForm
          ?formTitle        "Select file to view"
          ?buttonLayout     'OKCancel
          ?fields           list(
            list(fileName   0:0 400:hicLineHeight   100)
            list(selectFile 100:hicLineHeight 100:hicLineHeight)
            list(viewFile   100:hicLineHeight*2 100:hicLineHeight)
        hiDisplayForm(form)
      ); let
    ); procedure CCFviewFile
    Load the code and invoke using "CCFviewFile()"
    Hopefully this is what you were looking for?
    Best regards,
    Lawrence.
  • Sandeep4386
    Thanks a lot Lawrence. This is exactly what I was looking for. However this would allow me to select and view only one file at a time. Can I select and view multiple files?
  • skillUser
    Hi Sandeep,
    Ok, here's a different approach, "one button to do it all" - reminds me of Lord Of The Rings ;-)
      let( (selectFile form)
          ?name             'selectFile
          ?callback         strcat("hiDisplayFileDialog(?dialogName 'CCFselectFile"
            " ?mode 'existingFiles ?caption \"Select one or more files\""
            " ?callback \"CCFviewFileCB\")")
        selectFile->hiToolTip = "Browse for file(s) to view"
          ?formTitle        "Select files to view"
          ?fields           list(list(selectFile 0:0 100:hicLineHeight))
        hiDisplayForm(form)
      ); let
    procedure(CCFviewFileCB(dialog event)
      when(event=='done
        foreach(file hiFileDialogSelection(dialog)
          when(isFile(buildString(file "/")) view(buildString(file "/")) )
        ); foreach
      ); when
    ); procedure CCFviewFileCB
    This uses the hiDisplayFileDialog() function to allow one or more files to be selected and the callback is invoked from the file selection dialog Open button - the callback handles the viewing of each file.
    Best regards,
    Lawrence.
  • Sandeep4386
    Thank you very much Lawrence. Thant worked like a charm!
