  3. Spectre simulation settings
  • Views 18781
MatthewT
MatthewT over 11 years ago
I have a simulation that works correctly when I run it using ADE L GUI window. The simulation have some problems with convergence:
Trying `homotopy = gmin' for initial conditions.
Trying `homotopy = source' for initial conditions.
Trying `homotopy = dptran' for initial conditions...
however dptran method works.
Then I run the same simulation using .ocn script that I load in Virtuoso main window (load "path/script.ocn). The tran simulation is run two times. Firstly, to read some voltage values and secondly as a proper tran simulation. The first simulation convergence while the second not. I set these two tran simulations to be run with the same variables, but the problem still exists.
What is the problem? How can I check these two simulation settings to see whether there is a difference between them?
update1:
1) I can run tran 1, where the circuit converges, but in the following tran 2 the circuit does not converge.
2) I can omit tran 1 (by commenting run() function) and tran 2 converge.
This is really strange. I used this simulation and the other ones where I run tran two times one after another and everything was fine till now . .
I do not know what is going on . . .
update2:
Solved :) ! "delete('analysis)"  has been added before running the second tran analysis:
            delete('analysis)
            analysis('tran ?stop "245n" )
            envOption(
                'analysisOrder  list("tran")
            ); envOption
             run()
Source: community.cadence.com/.../26695
