  3. Sorting Schematic Instance by location
  • Replies 7
  • Views 17838
nosaj
nosaj over 11 years ago
How do I sort schematic instances ( cv~>instHeaders ) based on the X location on the schematic?
    I assume you meant cv~>instances rather than cv~>instHeaders (instHeaders are once per instantiated master, and can represent multiple instances of the same type - so an instHeader will have multiple xy locations, one for each instance). For that you'd do:
    instancesSortedByX=sort(cv~>instances lambda((a b) xCoord(a~>xy) < xCoord(b~>xy)))
  • nosaj
    My code uses instHeaders and still can't make it work with your suggestion.....could you correct it?
    foreach(ih cv~>instHeaders
        when( !member(ih~>libName skipLibList)
        instancesSortedbyX=sort(ih~>instances lambda((a b) xCoord(a~>xy) < xCoord(b~>xy)))
        foreach(inst instancesSortedbyX
          instNameList2 = cons(inst~>name instNameList2)
            printf("\tname=%s\txy=%L\n", inst~>name, inst~>xy)
    So what doesn't work? I tried your code, and for each instHeader, the instances are output sorted by the X coordinate.
  • nosaj
         foreach(inst ih~>instances
           instNameList = cons(inst~>name instNameList)
     printf("instNameList 1=%L\n", instNameList)
     printf("instNameList s=%L\n", sort(instNameList nil))
     printf("instNameList2=%L\n", instNameList2)
    OUTPUT :
        name=I0        xy=(-2.1875 1.125)
        name=I5        xy=(2.3125 0.3125)
        name=I2        xy=(-0.375 0.8125)
        name=Iz1    xy=(-1.375 0.0)
        name=I3        xy=(0.25 0.8125)
        name=I4        xy=(1.25 0.0625)
    instNameList 1=("I4" "I3" "Iz1" "I2" "I5" "I0")
    instNameList s=("I0" "I2" "I3" "I4" "I5" "Iz1")
    instNameList2=("I4" "I3" "Iz1" "I5" "I2" "I0")
    See the output from the 2nd foreach, the instances were not sorted by x coordinate, correct order should be I0, Iz1, I2, I3, I4, I5.
    Pretty sure I'm not doing it correctly if you got it to work.
    I suspect the most likely explanation is that the instances are not all part of the same instHeader. It's only sorting within each instHeader.
    Please change the second loop to:
         printf("instHeader: %L %L %L master=%L\n" ih~>libName ih~>cellName ih~>viewName ih~>master)
    and then post what the output looks like.
  • nosaj
    I took out the cv~>instHeaders and replace it with
          foreach(inst sort(cv~>instances lambda((a b) xCoord(a~>xy) < xCoord(b~>xy)))
            when( !member(inst~>libName skipLibList)
    And that works now.
    Output :
    I don't know why the original code uses cv~>instHeaders and loop another foreach instHeader~>instances.
    Is there any difference between [1] and [2]?
    [1]
    foreach (inst cv~>instances
    [2]
    forearch(ih cv~>instHeaders
      foreach(ih~>instances
    If you're only interested in certain masters and have conditional code around the inner foreach over the instances for that instHeader, then the two loop approach will be more efficient. If you are visiting every instance, then there's not much in it.
