  3. schematic toolbar file
  • Views 15092
psill000
psill000 over 11 years ago
Is there a file similar to Layout.toolbars for schematics
I have searched the install directories for toolbar files and did not find anything for schematics
Paul
  • skillUser
    skillUser over 11 years ago
    Hi Paul,
    The Schematic toolbar is in the same location as the other toolbars, i.e.
    <cds_install_dir>share/cdssetup/dfII/toolbars/byApplication/Schematics.toolbars
    Hopefully this will help you?
    Lawrence.
  • psill000
    Thanks for the info.
    Just to confirm a direction for schematic toolbar
    To create my own schematic toolbar, I would create a file Schematics.toolbar and have the syntax below to start the file.
        nil
        inheritToolbarsFrom "Schematics"
     ; Define my own toolbar items
    and place the file in the same place as the Layout.toolbar
    Paul
    Paul,
    Yes, although I would in general suggest looking at the Toolbar manager in IC616 as this allows you to define the toolbars using "overrides" which are better at handling changes when we update the Cadence toolbars (plus it's a graphical UI to define the toolbars which is quite straightforward).
