  3. Width dependent rows of subrectangels for rodCreatePath
  • Views 16121
archive over 20 years ago
I wonder if there is already a method in place to create
multiple rows (list for the ?subRect argument of  rodCreatePath)
of subrectagles, depending on the width of the master path?
I didn't want to invent the wheel twice.
Cheers Bernd
Originally posted in cdnusers.org by bernd.fischer@xignal.com
    Bernd,
    There's a PCR asking for this, but for now you have to create the multiple rows yourself.
    Originally posted in cdnusers.org by adbeckett
    Andrew,
    I knew about the PCR, but I thought someone out there
    could already have a solution for this, but it seems not.
    I'm close to be ready with my solution for it, if it's done
    I'll attach the code to this thread.
    Cheers Bernd
    ;; Disclaimer : NO WARRANTY, this SKILL function(s) is(are) released
    ;; without any warranty. The Author does not warrant,
    ;; guarantee, or make any representations regarding the
    ;; use, or the results of use of this SKILL function(s).
    ;; The entire risk of the use of this SKILL function(s)
    ;; is with you.
    ;; File Name : createSubRectList.il
    ;; Function(s) : BFcreateSubRectList
    ;; Author : Bernd Fischer
    ;; Date : Tue. 4. June 2006
    ;; Version : 1.0
    ;; Application : Virtuoso/Virtuoso XL
    ;; SW Release : 5.1.41 and higher
    ;; SKILL Lint : PASSed
    ;; Global Variable(s) : None
    ;; Synopsis : BFcreateSubRectList(
    ;; ?layer l_layerPurposePair
    ;; ?masterPathWidth n_masterPathWidth
    ;; ?subRectWidth n_subRectWidth
    ;; ?subRectSpace n_subRectSpace
    ;; ?beginOffset n_beginOffset
    ;; ?endOffset n_endOffset
    ;; ?sideOffset n_sideOffset
    ;; Description : This function creates a list or lists of subrectangle
    ;; arguments for the 'rodCreatePath' function.
    ;; It gives the rodCreatePath function the ability to create
    ;; multiple rows of subrectangels depending on the with of
    ;; the master path.
    ;; It can be called directly as value for l_subRect of
    ;; rodCreatePath or used in context with a variable which
    ;; holds the l_subRect value.
    ;; Arguments : txl_layer Text string, integer, or list
    ;; specifying the layer or layer
    ;; purpose pair for the sub
    ;; rectangles.
    ;; n_masterPathWidth Positive integer or floating
    ;; point number specifying the
    ;; width of the master path.
    ;; n_subRectWidth Positive integer or floating
    ;; width of the sub rectangles.
    ;; n_subRectSpace Positive integer or floating
    ;; spacing between the sub
    ;; rectangles.
    ;; n_beginOffset Signed integer or floating
    ;; offset of the edge of the first
    ;; subrectangle from the starting
    ;; edge of the master path.
    ;; n_endOffset Signed integer or floating
    ;; n_sideOffset Signed integer or floating
    ;; offset along the edges of the
    ;; master path to edges of the
    ;; most right and left subrectangle
    ;; row.
    ;; Return Value : l_subRectList
    ;; Example : rodCreatePath(
    ;; ?subRect BFcreateSubRectList(...)
    ;; or
    ;; l_subRect = BFcreateSubRectList(...)
    ;; rodCreatePath(
    ;; ?subRect l_subRect
    ;; Modification : None
    procedure( BFcreateSubRectList(
    @key
    layer
    masterPathWidth
    subRectWidth
    subRectSpace
    beginOffset
    endOffset
    sideOffset
    let( ( l_subRectList f_numOfRows x_numOfRows
    f_variableSubRectSpace f_separation
    ;; differentiation if one or more than one contact can be placed
    ;; then calculate number of rows as float
    if( masterPathWidth <= ( 2 * sideOffset + subRectWidth ) then
    f_numOfRows = ( masterPathWidth - ( 2 * sideOffset ) ) / subRectWidth
    else
    f_numOfRows = ( masterPathWidth - ( 2 * sideOffset ) + subRectSpace ) /
    ( subRectWidth + subRectSpace )
    ;; conversion of number of rows form float to integer
    if( ( ( round( f_numOfRows ) - f_numOfRows ) < 0.001 ) then
    x_numOfRows = round( f_numOfRows )
    else
    x_numOfRows = fix( f_numOfRows )
    ;; algorithm to calculate variable subrectangle spacing
    ;; to align subrectangels fix on enclosure with variable spacing
    unless( onep( x_numOfRows )
    f_variableSubRectSpace = ( masterPathWidth - ( 2 * sideOffset ) -
    ( x_numOfRows * subRectWidth ) ) /
    ( x_numOfRows - 1 )
    ;; create list of subrectangle arguments
    cond(
    l_subRectList = cons(
    list(
    ?layer layer
    ?width subRectWidth
    ?length subRectWidth
    ?space subRectSpace
    ?beginOffset beginOffset
    ?endOffset endOffset
    ?justification 'center
    l_subRectList
    ) ;; close cons
    ( t
    for( j 1 x_numOfRows
    f_separation = ( ( j - 1 ) * ( f_variableSubRectSpace + subRectWidth ) ) +
    ( subRectWidth * 0.5 ) + sideOffset -
    ( masterPathWidth * 0.5 )
    list(
    ?layer layer
    ?width subRectWidth
    ?space subRectSpace
    ?sep -f_separation
    l_subRectList
    ) ;; close cons
    ) ;; close for
    ) ;; close cond
    l_subRectList
    ) ;; close let
    ) ;; close BFcreateSubRectList
    It seems that somehow the formatting get lost while posting code, worse option?
    Some idea why?
    Bernd
