  3. Adding pulldown menu to ADE
  • Views 15482
meland
meland over 11 years ago
I'm trying to find the a way of appending a pulldown menu to the default ADE state. I am using cadence 6.1.5
Previous discussion: http://community.cadence.com/cadence_technology_forums/f/48/t/18056
Current solution: below is the contents of the file ./menus/spectre.menus
load(prependInstallPath("/etc/tools/menus/spectre.menus"))
(sevAddMenuItemLists (lambda (session name) (case name
  ("Example"
    list(
      hiCreateMenuItem( ?name 'MenuItem_1 ?itemText "Item1" ?callback "println('Item1)" )
    ) ;Example
(sevSetMainWindowPulldownMenus
  (let (menu)
   menu = `(
            "S&ession"
            "Set&up"
            "&Analyses"
            "&Variables"
            "&Outputs"
            "&Simulation"
            "Example"
    when( envGetVal("adexl.launchFromTest" "showMenu")
        menu = cons("&Launch" menu)
    menu
Issue: By using sevSetMainWindowPulldownMenus, and the hand created variable 'menu', the pulldown menu is hard coded opposed to a solution that takes the existing menu list and appends 'Example'. This is an issue if any the default menus ever change. Everything I have read seems to suggest that excluding the function sevSetMainWindowPulldownMenus should do exactly what I want. However, if I do exclude it, 'Example' does not show up anywhere. Without knowing how to query the current pulldown menu list, I'm stuck.
Matthew
    Matthew,
    Something like this should do what you want:
    let(((myOrigPulldownMenus copy(sevCustomEntity('sevMainWindowCME))))
      sevSetMainWindowPulldownMenus(
        foreach(mapcan menuName myOrigPulldownMenus
          if(menuName=="&Help" then
            list("Example" menuName)
          else
            list(menuName)
    sevAddMenuItemLists(
      lambda((session name)
        case(name
          ("Example" `(("Some Item" ?callback "MyDoThis()")))
  • meland
    This works perfectly. Thanks Andrew!
