  3. compare schematic and layout pins
  • Subscribers 150
  • Views 17149
vkannoth
vkannoth over 11 years ago
need a skill script which will compare schematic pins with layout pins in a given hierarchy.
    Andrew Beckett over 11 years ago +1
    Something like this might do what you want: /* CCFcompareTerminals.il Author A.D.Beckett Group Custom IC (UK), Cadence Design Systems Ltd. Language SKILL Date Jun 25, 2015 Modified By Compare terminals…
  • meland
    meland over 11 years ago
    Your question is somewhat vague. Have you tried anything?
    layout:
    a=geGetEditCellView()
    a~>shapes~>lpp
    a~>shapes~>theLabel
    schematic:
    a~>terminals~>name
  • vkannoth
    wanted skill script which will compare and dump out the mismatch between the pins in layout and schematics for a given cell.
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 25, 2015
    Modified
    By
    Compare terminals between two cellViews
    SCCS Info: @(#) CCFcompareTerminals.il 06/25/15.21:28:36 1.1
    *                 CCFcompareTerminals(cv1 cv2)                 *
    *      Compare terminals between two different cellViews       *
    *     and print out some information about the differences     *
    procedure(CCFcompareTerminals(cv1 cv2)
        let((termInfo termRec lcv1 lcv2)
            sprintf(lcv1 "%s/%s/%s" cv1~>libName cv1~>cellName cv1~>viewName)
            sprintf(lcv2 "%s/%s/%s" cv2~>libName cv2~>cellName cv2~>viewName)
            termInfo=makeTable('termInfo nil)
            foreach((prop cv) '(cv1 cv2) list(cv1 cv2)
                foreach(term cv~>terminals
                    foreach(termName dbProduceMemName(term~>name)
                        unless(termRec=termInfo[termName]
                            termRec=list(nil)
                        putprop(termRec term~>direction prop)
                        termInfo[termName]=termRec
            foreach(termName sort(termInfo->? nil)
                cond(
                    (termRec->cv1 && !termRec->cv2
                        printf("Terminal %s missing in %s\n" termName lcv2))
                    (termRec->cv2 && !termRec->cv1
                        printf("Terminal %s missing in %s\n" termName lcv1))
                    (termRec->cv1 != termRec->cv2
                        printf("Terminal %s - direction mismatch (%s : %s) (%s : %s)\n" termName lcv1 termRec->cv1 lcv2 termRec->cv2))
            t
  • vkannoth
    Thanks, Andrew. This is perfect.
    This is what i was looking for. only thing is i just need to assign cv1 & cv2 seperately.
    thank you once again!!
