  3. way to approach instance properties
  • Views 15940
dakuang01
dakuang01 over 11 years ago
I found a way to approach property of instances selected in schematic or layout. That is like below.
selectedSet()~>[CDF Parameter]
CDF Parameter is CDF Parameter name of Edit Object Properties.
Sometimes it works(returns the value), but someties it returns only (nil).
how can I check the lists of CDF Parameter the instance have?
  • meland
    meland over 11 years ago
    I haven't had issues with my limited use of the cdfGetInstCDF() function:
    obj=car(geGetSelectedSet())
    instParamNameList=cdfGetInstCDF(obj)~>parameters~>name
    instParamValueList=cdfGetInstCDF(obj)~>parameters~>value
  • dakuang01
    Thank you so much, meland!!
