  3. cancel button does not work when using hiCreateAppForm ...
  • Views 15629
cancel button does not work when using hiCreateAppForm function
gs748
gs748 over 11 years ago
In My SKILL script I am using the function  hiCreateAppForm which opens up a GUI which has button options => OK cancel Defaults Apply Help
Whenever I click on the cancel button it does not close the opened app form.
Below is the function I am using:
hiCreateAppForm( ?name 'CellForm
  ?formTitle "Cor_files"
  ?callback "CornerSet()"
  ?fields list( aRadio )
  ?help "cream" )
  status = hiDisplayForm( CornersForm )
Can anyone tell me how to make cancel button work.
    Adding a little bit of missing information:
    aRadio=hiCreateRadioField(?name 'aRadio ?choices list("one" "two" "three"))
    CornersForm=hiCreateAppForm( ?name 'CellForm
      ?help "cream" )
    You clearly didn't try the code you posted as problematic, or you'd have seen that it works fine. Of course, it's quite possible (from previous experience) that what you posted is not what you tried, or that there is some other important piece of information that  you omitted.
    At the very least, it's wise to try what you post to make sure it shows the problem you're describing, as otherwise everyone has to get their psychic sensors out to guess what you really mean. I could tell from looking at the code you posted that it wouldn't show the symptoms you've described, and sure enough, it doesn't. Without the red code above, it doesn't work at all, so the problem you're seeing is clearly induced by some piece of code you didn't supply.
