  3. Export values of output expressions
  • Views 18773
zyviva
zyviva over 11 years ago
In ADE L, I have created various expressions that are saved as outputs. After my simulation is complete, the values of these expressions (some number) is displayed under the value column in the outputs table. How can I export these values en masse?
There is an Outputs-->Export option, but that exports the expressions and I would like the values.
I am running version IC6.16-64b.500.6
Thanks.
  • skillUser
    skillUser over 11 years ago
    Hi Sarah,
    You could create an OCEAN script (Session -> Save Ocean Script) and modify it a little so that the values are printed out to a file. Keep the bits with the expressions and build the rest of the script around it, then you can load this file in the CIW or call it from the standalone "ocean" executable.  Here's a brief example:
    ::: printExprs.ocn  :::
    openResults("./simulation/<your_circuit>/spectre/schematic" ) ;; modify as needed
    selectResult('tran)
    filePointer = outfile("./results" "w")
    fprintf(filePointer ";; Output results for <your_circuit>\n") ;; modify as needed
    ;; iterate over the required nodes or you can print each expression
    ;; as it is from the original oceanScript.ocn file
    foreach((node val) list("/I0/D4/PLUS" "/I0/vout_R" "/I0/D4/PLUS")
                        list(2.8e-06 1e-05 1e-05)
      ocnPrint(?output filePointer
        strcat(node "\t")
        value(getData(node ?result 'tran) val)
    ); foreach
    close(filePointer)
    println("Simulation results output to ./results")
    ::: results :::
    /I0/D4/PLUS        2.81092n
    /I0/vout_R          0
    /I0/D4/PLUS        651.035p
    Note that you can use ocnPrint() to output to a file or file handle, it is simple to use but you may not have as much control as using fprintf statements directly (e.g. note the spacing between the output lines above).
    Hopefully this is the sort of thing that you are looking for?
    Lawrence.
    The other (probably better) alternative is to use ADE XL, and then you can export the results to HTML or CSV.
